Author Topic: What is this type of bulb or lamp?  (Read 721 times)
Offline AxxelTopic starter
« on: July 31, 2019, 03:14:11 pm »
Dear friends.
As I can see, this type of lamp is powered with 3000...4500V, it this case this lamp is used to generate ozone (???) and when it's powered it acts like a little plasma ball, but with a orange color.
Here they are selling this types of bulbs, and the tranformer:
https://www.todoelectronica.com/es/1695-lamparas-y-tranformadores
What is the type of this lamp, what type of gas have?
Hope you can help me!
Do you think this lamp is on purpose buided to make ozone OR this lamp is used for other thing in industry?
Regards ;D
« Last Edit: July 31, 2019, 06:41:17 pm by Axxel »
Offline technix
  • Country: cn
  • From Shanghai With Love
    • My Untitled Blog
Re: What is this type of bulb or lamp?
« Reply #1 on: July 31, 2019, 03:17:48 pm »
This looks like some kind of discharge tube to me.
Offline Stray Electron
« Reply #2 on: July 31, 2019, 03:37:47 pm »
  Orange discharge would indicate that it's filled with neon gas.  What does the label say? 3000 volts sounds HIGH! Is that continuous or only pulsed? I've never heard of a neon lamp that produced ozone, most of the lamps that produce ozone are mercury vapor lamps and they emit mostly UV-B and UV-C and they have a quarz (not glass) tube because quartz passes the UV better.   Are you SURE that 3000 volts isn't the ignition voltage and that the operating voltage isn't considerably less?
   You might want to go look up UV germicidal lamps.
   You can go buy one of those piezo-electric spark generators like those that are used to ignite gas grills and hold the wire next to the glass envelope and fire it and it will usually made a flash inside the tube and you can tell from the color of the flash what kind of gas is it.   You can find the spark generators at Home Depot in the US. You don't have to connect to an electrode on the lamp just place the wire lead next to the glass and that is usually enough to generate a small flash.
   PS.  The old EPROM erasers also used UV lamps in them to erase the contents of the EPROMs.
   Fair Warning!  UV, particularly UV-B and UV-C is extremely damaging to the eyes and somewhat damaging to exposed skin. You've been warned.
« Last Edit: July 31, 2019, 03:42:46 pm by Stray Electron »
Online themadhippy
« Reply #3 on: July 31, 2019, 04:25:25 pm »
Or low pressure sodium
Offline duak
« Reply #4 on: July 31, 2019, 05:21:04 pm »
I think it might be from an ozone generator: http://www.jelight.com/wp-content/uploads/2018/03/Model-610b.pdf
I'm guessing it's a low pressure mercury lamp that has neon in it to improve the mercury UV discharge.
« Reply #5 on: July 31, 2019, 06:40:11 pm »
Thanks for your answers!
Here I added more informations on the main topic!
Regards.
