Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
General
General Technical Chat
[TIPS] How to identify SMD devices from the marking codes
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: [TIPS] How to identify SMD devices from the marking codes (Read 2094 times)
gamalot
Super Contributor
Country:
Correct my English
on:
March 29, 2018, 06:03:29 pm »
The answer is taobao.com, search in Tabao by using the marking code as keyword, you will find it has never been so easy!
Logged
https://youtube.com/@gamalot
https://github.com/gamalot
DC1MC
icezebra
Contributor
Country:
Re: [TIPS] How to identify SMD devices from the marking codes
Reply #1 on:
February 05, 2023, 08:13:38 pm »
Thank-you, this is very helpful. I also got traction doing the same thing on
www.Ali-Express.com
Also, note that characters sequences that appear to start with upper case 'I' may actually be a vertical bar that must be omitted from your search. The attached photo marking code "IP5MW" was identified by searching
TSOP23
and
P5
(Searching more than two or three leading chars will yield poor results as trailing chars may be date codes)
Resulting part number: MP2370 (Datasheet attached, to see the vertical bar in the marking code)
Also see this:
https://www.eevblog.com/forum/repair/fluke-179-repair-info-incl-partial-parts-list/msg4162816/#msg4162816
and this:
https://ipcamtalk.com/threads/reolink-hardware.68214/#post-740670
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
General
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
