Surely the logical thing is to institute a regime where you do the "turn all the standby stuff off at the mains switch" thing for a month,
then do another month with your normal set up,reading the power meter at the beginning & end of each,& comparing the results of both periods.
Both months would obviously need to have similar weather,as otherwise, if you use Electrical heating & clothes drying equipment,that could distort things.
