Need something (or even a few things) printed on a 3D printer but don't have one yet?
I can print it for you and mail it to you at no charge (assuming shipping is reasonable -- it is in the states). All I'd like in return are some quality resistors measured and values recorded with a very well calibrated 6 digit multimeter, so I can use them as a reference point to test my multimeters. I assume that decent resistors don't really drift in value much over the years no? (I could be wrong but I am not that picky either.. my meters are only 4.5 and 5.5 digits -- can't afford 6.5 meter). The resistors don't have to be the super expensive $15-25 ones.. maybe three different values in the $1-$5 range. Whatever 3 values you think would be best to use as a 3 way reference.
If you need a lot printed, I wouldn't mind the expensive Vishays
I think the ones Dave use (the two) are like $15 & $25 each oh my! That'd be a lot of printing ! But I'd so do it for them
But again, the cheaper ones are okay for less print jobs
Thanks
