Author Topic: WTB - Data I/O 29B Universal Programmer (or equivalent)  (Read 4587 times)
Offline deanclaxtonTopic starter
« on: January 23, 2020, 03:05:20 am »
I'm looking for a universal programmer that can handle all the old obscure bipolar PROM's EPROM's etc. Something like the Data I/O 29B.
If the price is right, I'm happy to buy a unit that needs some work (hoping I'll be able to get it going again!).
Let me know what you have, or if you have any recommendations on an alternative programmer I should be looking out for on eBay or similar!
Cheers,
Dean
« Last Edit: January 23, 2020, 09:58:13 pm by deanclaxton »
Online coromonadalix
Re: WTB - Universal Programmer
« Reply #1 on: January 23, 2020, 12:40:55 pm »
Normally you should have an idea of the parts you want to use and program,  you tell us nothing  by the way  loll
Check all the major brand supprted part lists,  there is no aboslute / ultimate programmer ... you'll get an idea and how much $$$ it may cost
A TNM-5000 is a very good contender at around 300$ usd or less, frequent updates and use cheap simple adapters ...
Find a programmer whos not locked onto its adapters sockets  vice verca ...   i have an Elnec and some adapters cost a fortune.
The famous tl866,  now has an old version who could program some chips at higher voltage than the newest version, i have the first series,  kinda limitted, and in my case support wasn't good from autoelectric, and the software support may end soon or will end eventually in favor of the newests models, but some of the adapter sockets have id chips on them.
my 2 cents
« Reply #2 on: January 23, 2020, 09:40:16 pm »
Thanks - ultimately I'd like to be able to program any of the devices listed here:
https://www.mikesarcade.com/cgi-bin/spies.cgi?action=url&type=info&page=PromRef.txt
Perhaps the Data IO is the way to go - I do have a couple of BP Micro programmers (BP-1148, EP-1140), 1,  plus a Xeltek Superpro 510p and a TL866 - the last two are useful for more modern devices (plus they run under Windows 10!), and the BP ones handle some of the earlier EPROMS, but not the PROM's.
Ideally I'd get rid of the BP units after I had something that will do all the earlier devices.
Offline Stray Electron
Re: WTB - Data I/O 29B Universal Programmer (or equivalent)
« Reply #3 on: January 24, 2020, 02:20:24 am »
   I have a couple of 29s somewhere. But IIRC they require the correct plug in for the EPROM, PROM or PAL that you want to program and IIRC the plug in for the bipolar PROMS was very hard to find even 20 years ago. Also IIRC the blank PROMS have been out of production for 30+ years and I couldn't find any 15 or so years ago when I wanted some to reprogram an HP 1000.
  Do you have a manual for the -29 that shows what plug ins you need for the devices that you want to program?
   And FYI I don't think that the -29s will program the 1702 and similar P-MOS EPROMs if you're interested in those.  I have an old Pro-Log programmer that kept specifically for that task.
« Reply #4 on: January 24, 2020, 02:51:51 am »
Thanks - yeah I believe that there is a UniPak 2B that will do most of them? If I'm able to get hold of a 29B (or even a 29A), then a Unipak 2 sounds like its a necessity.
Found this : http://matthieu.benoit.free.fr/dataio/1986_Wall%20Chart.pdf
For some devices,  socket adapters are required - perhaps these are simple PCB's that could be reproduced? For a few, Cartridges are required such as the 351B-086 - I'm not sure whether these are simple or not. For many devices though, the Unipak 2B is all that is required.
More Info :
"SPECIFICATIONS
UNIPAK 2B
COMPREHENSIVE MEMORY DEVICE SUPPORT
The UniPak 2B,™ with a Data I/O® mainframe, programs vir-
tually every memory device under software control from
over 33 manufacturers. These include EPROMs, EEPROMs,
microcomputers and PROMs of all bipolar fuse technol-
ogies; fuselink and vertical fuse. More than 90% of these
devices are supported with no additional adapters.
CARTRIDGES SUPPORT UNIQUE ALGORITHMS
A key enhancement over earlier UnlPak and UniPak 2 is the
UniPak 2B's support for optional slide-in pinout cartridges.
These cartridges allow users to reliably program devices
which are not programmable with the base UniPak 2B,
regardless of pinout configuration or packaging. Car-
tridges provide the UniPak 2B with the flexibility to program
the latest complex device types and hard-to-handle
packages, such as 40-pin one megabit EPROMs, PLCCs,
and other surface-mount devices.
USES INTELLIGENT ALGORITHMS
Like its predecessors, the UniPak 2B speeds the program-
ming process through the use of intelligent algorithms.
These algorithms eliminate redundant programming pulses
by checking memory cells after each pulse to see if they
have been programmed. "
So the cartridges would be tricky to replicate if required, but seems it will handle many devices without any additional adapters.
« Last Edit: January 24, 2020, 05:26:51 am by deanclaxton »
Offline PaulAm
« Reply #5 on: January 24, 2020, 08:08:00 pm »
If you're looking at a 29B, you should check out the dataio group on groups.io.
There were some production changes through the life of the model and early ones cannot be updated to the latest firmware, IIRC.  There are also some gotchas on upgrading the memory if you want to do that.
The cartidges aren't that big a deal, it's the device support that's important.  You can't program it if the 29b doesn't support it and you can't add new devices.  It is really good for the devices it supports though.
« Last Edit: January 24, 2020, 08:11:32 pm by PaulAm »
« Reply #6 on: January 25, 2020, 01:07:42 am »
Thanks - I'll be sure to check out that group!
Offline PlainName
  • Country: va
« Reply #7 on: January 25, 2020, 11:09:17 am »
Another alternative could be the Dataman 48LV:
https://www.dataman.com/dataman-4848lv-resources
Long in the tooth now, but then so is the DataIO and whatever you're wanting to program ;)
« Reply #8 on: January 25, 2020, 11:34:46 am »
Awesome - will look into the Leap U1 and Dataman as well - thanks guys :)
« Reply #9 on: February 08, 2020, 10:48:48 am »
Another good candidate is the Advantech LabTool-48 or 48UXP - wont do the really old EPROMS, but seems to support 2716 up and many other older PROM's, GAL's etc.
« Reply #10 on: December 07, 2021, 10:55:06 pm »
Thanks Tony - I imagine it would cost a bomb to get it here (Australia) though?
Offline hirsutus
« Reply #11 on: July 04, 2023, 05:13:52 pm »
Hello Dean,
I haven't been back here in a while but I sold it to a guy in Vilnius. We chose UPS to ship it, it wasn't cheap.
Tony.
Offline KG7AMV
  • Rhine_Labs
    • My Personal Blog
« Reply #12 on: July 05, 2023, 02:47:09 am »
I do a lot of device programming. I use Xeltek Programmers massive device support weekly device updates and they support custom devices.
https://www.xeltek-cn.com/devsearch/?source=USA&lang=en-us
6100N Device List It has the Largest BProm Support of the modern programmers.
https://www.xeltek-cn.com/devlist/xsp6100N.htm
There is also a Homebrew and Paid solution for the proprietary adapters to be able to use basic SA or DIY adapters. There are also china sources for official ones at 1/3rd the cost.
Facebook User Group.
https://www.facebook.com/groups/xeltek
« Reply #13 on: March 16, 2024, 12:26:37 am »
Old thread I know, but I did end buying a Xeltek 6100N some time ago. I have a Magic Adapter (https://www.youtube.com/watch?app=desktop&v=51IF3-WTmQQ) on it which allows it to emulate a bunch of different Xeltek programming adapters. This means that as long as the device that you want to program is 48 pins or less, you can install a low cost 1:1 pin mapping adapter into the 48 pin DIL socket, then dial up the Xeltek progamming adapter part number on the Magic Adapter, and it reports back to the programming software that you have the correct adapter installed.
« Last Edit: March 16, 2024, 12:34:46 am by deanclaxton »
The following users thanked this post: coromonadalix
Offline KG7AMV
  • Rhine_Labs
    • My Personal Blog
« Reply #14 on: July 19, 2024, 06:03:51 pm »
I made a PCB for my Magic Chip to break out all 144 Pins and to be able to use the same public adapters are the Newer Maga Magic. My Board Also works with the public V1 Magic Chip for the 5000E and 6100N Pre September 2019.
« Last Edit: July 19, 2024, 06:13:13 pm by KG7AMV »
Offline propellerhead
  • Give me Robertson or give me death.
« Reply #15 on: July 20, 2024, 03:26:49 am »
A little weird to issue a correction to a really old thread, but since it's been revived...
To be perfectly accurate, the firmware where the device support resides is not in the Model 29 mainframe.  It's in the UniPak/2/2B programming adapter.
The UniPak2 and UniPak2B are functionally identical; in fact, Data I/O used to sell a kit for repackaging the 2 into a 2B.  The difference is that where the 2's
biggest socket is 28p, the 2B uses the cartridge for anything bigger than a 24 - the 28, 40, micros, PLCCs, etc.  And yes, the UniPak2/B requires a memory
board with higher capacity for later firmware versions.  But this isn't the place for endless details; join the group mentioned above and all will be revealed.
