Greetings.
Update 1: found almost everything. Only need D module now. Where can one locate something like this?
Update 2: Found everything including the last module which was inside of the
exact power supply I was looking for
I might be able to rig / transmute M module into something like D. Not sure about higher voltage dual rail modules. But for some reason Only D module has common 0V for two rails.
I _was_ looking for a whole TDK Lambda Sirius CSF series power supply for AeroFlex IFR 3413 SigGen that is missing one.
Main rails have to be 12V-10A, 5V-25A*
Actual voltage need to be 6.5V, but according to datasheet it is adjustable 4.5-8.0, which means 5V and 6.5V models are the same with different adjustments.
These suckers are modular. Finding the right one might be hard.
I'll probably have to hunt down secondary modules separately. Since they all have different combinations of voltages too.
I need H and D modules
H module is 12V 4A and 26V 2A
D module is 5V 5A and 3.4V 5ADatasheet is here,
here,
and
hereI think SigGen has room for CSF350 model, which is bigger, but seems to be the same in most of the parameters except higher overall power
CS series (without F) is at least noisier and can't work without a load according to the datasheet and does not have the same feedback interface on the back.
Does anybody have one of those power supplies or modules collecting dust somewhere?
Thanks,
Andrey
