Author Topic: FOUND WTB Oscilloscope for beginner ( Europe )  (Read 1925 times)
Offline WackyGermanTopic starter
« on: June 25, 2014, 02:52:24 pm »
Would like to buy an oscilloscope for beginners . An analog or an easy simple to use dso with 2 channels would be great .Could be about 50 MHz bandwith or less . The smaller , the better , I haven t so much space on my workbench . I would like to use it for measurings in low frequency purposes and for component testings .  I also look for some probes and a component tester . Please make your offers , thank you
« Last Edit: July 01, 2014, 04:47:31 pm by WackyGerman »
Offline KJDS
    • my website holding page
Re: WTB Oscilloscope for beginner ( Europe )
« Reply #1 on: June 25, 2014, 07:10:57 pm »
I've just finished testing a batch of Gould 15MHz and 20MHz two channel analogue scopes. Simple to use and all working as they should do.
£40 for the 15MHz one. an OS255, £50 for the 20MHz units, OS300. Shipping to Germany will be £22.
PM me if you're interested.
Offline BTO
« Reply #2 on: June 28, 2014, 06:32:54 pm »
well , there's not arguing Quality ... is there
if your a beginner, i recommend Rigol DS2072A 70 MHz Scope
and then get the upgrade (see me for it if you like)
get the upgrade to 300MHz and 56 Mpts Memory Depth and all Trials Unlocked
2 Gsa/s
all Hacks aside,
its still a good little scope to start with and bum around with
it's not a Shwarz but Hey, it's still OK for beginners and too pricey
consider it
on the other hand, if you have enough for a Shwarz,  it's the better quality one, hands down
but it will be lower spec'd in comparison to the Rigol
QUESTION EVERYTHING!!!
« Reply #3 on: June 29, 2014, 06:42:47 pm »
Found one . Now I can play around and learn until  :-BROKE :-+ :-DD
