Very common problem with these meter movements, you can find a donor meter front from a HP power meter, i.e. the 435A/B, not many people want them due to lack of working power sensors. The donor unit would give you the spare wire stand & voltage selector too. Edit: they use a different voltage selector, built into the power inlet.
I've had to buy a few units, to salvage the meter casings & parts to repair delivery victims, with care the plastic zero part can be swapped over, from a smashed casing too.
