Sure
Well - all of the above. Though I don't plan to repair the front end of these sensors, which are the most likely failure
I do have a range calibrator, but you can always use another
Main reason is for creating sensor for low frequency - down to 10-100kHz
A broken sensor would be a nice enclosure to start with
Also playing around with some noise source designs
