Author Topic: Wanted: V + I display with high side sense (~30V ~10A)  (Read 1461 times)
Offline PsiTopic starter
« on: January 03, 2014, 08:20:17 am »
Hey,
Has anyone come across a smallish panel mount V and I display that does high side current sense and can power itself without needing an isolated supply.
There's lots available but all i've seen so far do low side sense and/or require a 2nd isolated supply.
It needs to measure up to say 24V (with 1 or 2dp) and anywhere around 5-10A for current, 0dp is fine but 1dp preferred.
I will keep looking but thought someone on here might have seen one before
Thanks
« Last Edit: January 03, 2014, 08:28:22 am by Psi »
Offline sorin
Re: Wanted: V + I display with high side sense (~30V ~10A)
« Reply #1 on: January 03, 2014, 11:58:16 am »
