Author Topic: Vintage Analog Integrated Circuits  (Read 824 times)
Offline FludoTopic starter
  • EE
« on: November 11, 2018, 01:24:16 pm »
For sale are several precision amplifiers,DAQs,ADCS, and voltage references.  Perfect for experimentation, data collection, or repairing instruments.
All packages are gold/ceramic through hole and have been stored in ESD protective bags, none of these components have been soldered/de-soldered.  Item will be packaged and ship at ESD workstation with proper packing materials. I have quantity of each available; prices lower with multiple purchases, PM with interest.
732DM-5 1GHz Relay 5V coil  -$15
Datasheet:https://www.mouser.com/datasheet/2/404/732-10744.pdf] [url]https://www.mouser.com/datasheet/2/404/732-10744.pdf[/url]
AD522BD Instrument Amplifier -$20
Datasheet:https://www.mouser.com/datasheet/2/609/adi_ad522-1214988.pdf
AD521JD Instrument Amplifer -$20
Datasheet:https://www.analog.com/media/en/technical-documentation/data-sheets/ad521.pdf
LF11331D Analog Switch -$20
Datasheet: https://www.digchip.com/datasheets/parts/datasheet/321/LF11331D-pdf.php
AD588BD Multiple Precision VRef -$30
 Datasheet: https://www.analog.com/media/en/technical-documentation/data-sheets/AD588.pdf
AD7581AD 8 Bit 8 channel data aquisition system with PGA -$75
Datasheet: https://www.analog.com/media/en/technical-documentation/data-sheets/AD7581.pdf
AD531LD Analog Multiplier - $25
 Datasheet: https://www.analog.com/media/en/technical-documentation/obsolete-data-sheets/115810432ad531.pdf
Application Note: https://www.analog.com/media/en/training-seminars/design-handbooks/ADI_Multiplier_Applications_Guide.pdf?doc=AD633-EP.pdf
AD534JD Analog Multiplier - Sealed in ESD bags - $30
 Datasheet:https://www.analog.com/media/en/technical-documentation/data-sheets/ad534.pdf
AD570JD 8 Bit ADC damaged by ESD foam during storage - $5
Datasheet: https://www.analog.com/media/en/technical-documentation/data-sheets/ad570.pdf
AD369AM 12BIT ADC -$50
Datasheet - https://www.analog.com/media/en/technical-documentation/obsolete-data-sheets/59914436971671AD368.pdf
