Author Topic: VFD display for HP 34401a multimeter wanted  (Read 11238 times)
Offline John_LTopic starter
« on: February 12, 2013, 11:24:18 pm »
Looking for new Fluorescent display for one of my older HP 34401 that is gone fairly dim.
On ebay only one source from China for about US$105 including shipping. http://www.ebay.com/itm/HP-AGILENT-34401A-Display-/251169866676?pt=LH_DefaultDomain_0&hash=item3a7ae403b4.
This is the description of the item.
""New other (see details): A new, unused item with absolutely no signs of wear. The item may be missing the original packaging, or in the original packaging but not sealed. The item may be a factory second or a new, unused item with defects""
I don't like the sound of factory second and unused item with defects, also don't know the origin of the product.
Can anyone recommend any other source for the display?
Cheers
John
Offline free_electron
    • SiliconValleyGarage
Re: VFD display for HP 34401a multimeter wanted
« Reply #1 on: February 13, 2013, 12:50:11 am »
that's your only chance. agilent doesn't sell them, only the complete fornt panels and they're pricey ( 300$ )
« Reply #2 on: March 01, 2013, 11:41:09 pm »
Replaced VF display with http://www.ebay.com.au/itm/HP-AGILENT-34401A-Display-/251169866676?pt=LH_DefaultDomain_0&hash=item3a7ae403b4.
Works fine and I can't see any difference in quality or brightness when comparing to my other newer Agilent 34401A meter.
Actual part no. is SAMSUNG SSVD INB-12MM52T.
Offline nukie
« Reply #3 on: March 02, 2013, 11:57:10 pm »
The Chinese clone is $45 not including shipping, don't know about operating hours, better get the mention Samsung.
Offline nukie
« Reply #4 on: March 03, 2013, 12:09:33 am »
Sorry about my crap phonecam, haven't got time to install it, its as bright as the original display, according to the seller.
Offline schopi68
    • My stuff page
« Reply #5 on: December 03, 2014, 09:23:49 am »
Well, including tax fee etc. I paid ~85 Euro for the Chinese Ebay-Version.
Keysight sells the front panel (VFD mounted on PCB for replacement) for ~100 Euro (inkl sales tax) here in Germany. According to the Keysight part Number finder is the US-Price at 93,52$.
(I am writing this as i went the wrong way first - i bought the ebay-Version which destroyed the transformer of my 34401a because i had overseen that there is a electrical connection on the outer side of the chinese vfd which builts a short to the esd-shield).
Offline HighVoltage
« Reply #6 on: December 03, 2014, 10:48:41 am »
I also bought a new original PCB with VFD installed from Agilent Germany, since I did not trust the China version on ebay.
Interestingly the new VFD from Agilent is even brighter than the VFD of a relative new 34401A. The cost was a little over Euro 100 including shipping and VAT.
Offline caall99
« Reply #7 on: December 03, 2014, 03:07:58 pm »
I have a new 34401A VFD that i purchased a while ago with the intent of installing into one of my meters. I don't think i will have a use for it anymore. New in box. You can PM me if you are interested.
Calibration Equipment:
Calibrated Agilent 3458A, Datron 4000A, Datron 4708, EDC MV100G, EDC MV105
Other toys: HP 3457A, HP 3456A, HP 34401A, HP 33120A, Agilent E3642A, Agilent E3648A
Offline on4top
« Reply #8 on: December 29, 2016, 02:14:19 am »
Got one from china this week ... but dodgy ..
I was well packed .. but 2 wires are broken inside ..
http://www.benl.ebay.be/itm/1PCS-NEW-HP-AGILENT-34401A-Display-VFD-vacuum-Fluorescence-Display-CCX-/181666132321?hash=item2a4c253161:g:H9AAAOSwstxU3Z2l
Contact seller ..  he send me new one or refund me ..
I asked for new one .. hope thisone wil be ok ?... seem to be verry fragile to send .. it was packed verry well in bubbel wrap and a big box ..
Offline SvanGool
« Reply #9 on: December 29, 2016, 09:36:02 am »
I got one coming in from the same company, fingers crossed.
While installing and testing this one, did you have the previous mentioned
Quote from: schopi68
I bought the ebay-Version which destroyed the transformer of my 34401a because i had overseen that there is a electrical connection on the outer side of the chinese vfd which builts a short to the esd-shield
problem?
# Don't hurry, the past will wait. #
Offline on4top
« Reply #10 on: December 29, 2016, 10:08:18 am »
esd-shield is probably the 2 copper strips above and botton of the VFD ?
 i did not installed them back yet ...tested w/o them..
good to know ... and check ..when i get new one ..
Offline SvanGool
« Reply #11 on: January 02, 2017, 11:36:31 pm »
I received the new display today,I de-soldered the original one and soldered in the new one, that kept me busy a couple of hours. Although it was not an exact (maybe just too much tolerances) fit, I had to bend the studs of the shield a bit, it is working.
I think the "ESD-shield" is indeed the EMI-shield around the display. I did not connect anything else than the pins on the bottom side, so I made no contact to the EMI-shield with one of the unused pads at the side of the new display, which the old one didn't have.
Offline schopi68
    • My stuff page
« Reply #12 on: January 27, 2017, 11:15:57 am »
Referring to the service guide the part mentioned is A2 M600, documented as "Shield-ESD".  ;)
But technically you're right, it is an EMI-shield (as noted i.e. in this Patent: http://www.freepatentsonline.com/7515219.pdf )
(and leaving it out may disrupt the emi-specifications of the device)
« Last Edit: January 27, 2017, 11:27:03 am by schopi68 »
The following users thanked this post: SvanGool
Offline janoc
« Reply #13 on: January 27, 2017, 05:20:48 pm »
I have been solving this exact issue just recently.
I have ordered a replacement from this vendor last October (doesn't seem to have anything on sale now, but it is Chinese New Year, so check in a week or two):
http://www.ebay.fr/usr/shop*forparts
The display has arrived fine, well packed and works like the original. If you decide to get one, be careful to check for exposed contacts on the sides. The original VFD has them insulated. I have put there some electrical tape to prevent them from touching the metal shielding frame holding the VFD and shorting out the power supply. I think that is the issue @schopi68 was referring to.
The hardest part of the repair is probably disassembling the meter - even with the service guide it can be a bit non-obvious how to take the chassis apart (do not pull at the ribbon cables/connectors, one has to push the connector down to release it!). Desoldering the old VFD and putting in the new one has been perhaps 10 minutes of work tops.
« Last Edit: January 27, 2017, 05:28:12 pm by janoc »
Offline bitseeker
« Reply #14 on: January 28, 2017, 03:40:53 am »
Yes, disassembly is rather non-obvious and the manual's description isn't very obvious until after you succeed. Thanks for the warning about the exposed contacts.
The following users thanked this post: jackenhack
Offline ian.ameline
« Reply #15 on: March 27, 2018, 08:33:13 pm »
Keysight is selling the board assembly (with display) for $138 US. They have 8 left in stock. (It was 9 until I ordered one.)
Part #34401-65522
Offline bitseeker
« Reply #16 on: March 27, 2018, 09:10:47 pm »
Be sure to check with Keysight that your DMM is compatible. Early 34401A models would not work with newer displays last I heard.
Offline ian.ameline
« Reply #17 on: March 30, 2018, 01:11:40 pm »
I gave them my serial number -- it works fine. It's a revision 3 display :
Offline bitseeker
« Reply #18 on: March 31, 2018, 01:19:53 am »
Yes, you have the newer DMM (black LO jacks). Looks great!
Offline ian.ameline
« Reply #19 on: March 31, 2018, 04:41:58 am »
Date codes & stamps inside show it was manufactured at the beginning of November, 1999.
With the new display board, it looks and acts like new -- nicely aged reference, calibration from Keysight within the last 12 months. And all for around USD $380 (including the new display)
Offline HighVoltage
« Reply #20 on: March 31, 2018, 09:13:01 am »
Congratulations on your success.
That is indeed a good deal for a good working 34401A
In Europe, the good working units go for $ 500 or more.
Offline janoc
« Reply #21 on: March 31, 2018, 12:33:49 pm »
Got mine for 257 euro in 2016, delivered. Including a still valid cal :-p It was working perfectly fine, just needed some grime cleaned off, the rear plastic bezel was cracked in two places (easily fixed with a drop of glue) and replacing the dim VFD (the Chinese one works fine). I have also bought the bumper and handle kit for it because it didn't have them (it came from a rack).
But yes, I wrote to the eBay seller afterwards that they are crazy to sell them for such price. And he actually offered me a second one :) Come to think of it, should have bought it too and resold it.
« Last Edit: March 31, 2018, 12:39:56 pm by janoc »
Offline charlyd
« Reply #22 on: April 03, 2018, 09:50:15 pm »
i got one for my 34401a from the same adress 1/2 year ago.. works great   uuuh yes $105 total. but after a week you dont remember anymore ;-)
