Author Topic: TVM802AX PNP + extras asking $2500  (Read 972 times)
Offline diyengineeringTopic starter
« on: October 15, 2018, 11:36:45 pm »
Selling a used/like new TVM802ax PNP machine, setup and used for roughly 40 hours on one project using all 26 feeders.
everything worked well, but is more thank I need at this time.
Originally paid $4000 for unit only, lots of extras including mouse/kb/monitor/extra nozzle set.
Asking $2500+shipping. Located in central Florida, will ship domestically.
specs:
Max applicable PCB
20mm*20mm—340mm*340mm
Max XY Moving area
395*450mm
Placement head quantity
2
Positioning accuracy
0.025mm
Max mounting capability
6000 PCS/H
Motor control scheme
Stepper motor (flexible S type acceleration / deceleration) ,  high voltage driver
Industrial computer
SSD 32G, Intel 2core
Applicable Components
0402--5050,SOP,TQFP,QFN  etc
Components supply
Tape reel,bulk,Tray
Tape width & Feeders number
Total=29, 8mm=25, 12mm=3, 16mm=1
Visual systems
2 HD CCD Cameras
UP Visual system
Identify angle deviations and position deviations
Down Visual system
Automatic identify mark point of PCB
Pump
1 vacuum pump(-92KP), 1 blow pump
Leakage material detection
Vacuum
Power
125W
Power Supply
AC220V or AC110V
Gross weight
67 kg
Net Weight
37 kg
Volume
0.38 CBM
Support software
Protl99/Altium Designer/Eagle/Pads/ Allegro
« Last Edit: February 25, 2019, 03:05:20 pm by diyengineering »
Re: TVM802AX PNP + extras
« Reply #1 on: October 17, 2018, 02:04:13 pm »
hi,
in the AX model the computer is built into the machine, the monitor, mouse and keyboard just attach to the machine.
