Author Topic: Tekequipment CT-71 Fixture Wanted  (Read 474 times)
Offline scopemanTopic starter
« on: September 05, 2024, 02:29:25 am »
Hello,
I am looking to buy the TO-3/T066 Fixture (the same fixture covers both types) for the Telequipment CT-71 Curve tracer.
Also if you have one and don't want to part with it I would appreciate some hi res pictures with measurements if possible.
Thank you,
Sam
W3OHM
W3OHM
Offline tautech
Re: Tekequipment CT-71 Fixture Wanted
« Reply #1 on: September 05, 2024, 02:35:45 am »
Any chance one of the Tek fixtures might fit ?
https://w140.com/tekwiki/wiki/Telequipment_CT71
Offline Wallace Gasiewicz
« Reply #2 on: September 13, 2024, 01:44:12 pm »
Years ago I repaired a Telequipment Scope.  It was a very close knock off of a Tek Scope.
 Possibly the other equipment are also very close to Tek
Offline tautech
« Reply #3 on: September 13, 2024, 08:25:14 pm »
Telequipment had their own development path and then they were purchased by Tektronix where some designs became quite similar.
Some Telequipment used Tek parts, eg the D83 I had used the same CRT as 7603 IIRC.
D83 were quite similar to Tek 500 models and also used plugin modules.
There is good reason why some Telequipment models are in the Tekwiki.....
« Reply #4 on: Today at 12:51:07 am »
Unfortunately the CT71 was unique and other fixtures will not work. If anyone has the TO3/TO66 fixture I sure would like inside outside pictures other than the ones on-line.
Thanks,
Sam
W3OHM
