Author Topic: looking for suppler of (stpr1020ctw or alternative)  (Read 2103 times)
Offline thegamer579Topic starter
« on: December 27, 2012, 03:11:09 pm »
hi there i am after a uk based suppler of ether the stpr1020ctw or a suitable alternative this is a part that has proven hard to find within the uk any help would be much appreciated.
« Last Edit: December 27, 2012, 03:47:43 pm by thegamer579 »
Offline Bored@Work
Re: looking for suppler of (stpr1020ctw or alternative)
« Reply #1 on: December 27, 2012, 05:20:03 pm »
From a former crown colony / dependent territory would be ok, too? http://www.ebay.com/itm/5-PCS-STPR1020CTW-TO-220-STPR1020-RECTIFIER-DIODES-/370721002986?
Offline electrician123
« Reply #2 on: January 03, 2013, 11:37:05 am »
Any where from Uk would be fine for you?
Offline lewis
  • Nullius in verba
« Reply #3 on: January 03, 2013, 04:27:54 pm »
DO NOT BUY FROM EBAY!!!!!
Let's find an equivalent:
http://uk.farnell.com/diodes-rectifiers
You need a:
  • Dual Common Cathode
  • >10A
  • >200V
  • Ultrafast
  • Low Vf
  • Uninsulated TO220
Here are the results sorted by price
MBR10200CT looks good! (Always check the datasheet, don't take my word for it)
I will not be pushed, filed, stamped, indexed, briefed, debriefed or numbered.
