Author Topic: Rework Station or Soldering Station?  (Read 17987 times)
Offline ShadowReaperTopic starter
  • Country: gr
« on: August 07, 2010, 08:56:01 am »
I am thinking of buying the aoyue 968:
http://www.aoyue.com/en/ArticleShow.asp?ArticleID=359 which has both soldering iron and hot air and I can afford the money for the station.
What's your opinion about the station?
Should I buy it or it would be better to buy a soldering station only (without the hot air)?
« Last Edit: August 07, 2010, 10:09:39 am by ShadowReaper »
Offline Simon
  • Global Moderator
    • Simon's Electronics
Re: Rework Station or Soldering Station?
« Reply #1 on: August 07, 2010, 12:58:17 pm »
Depends on what you want to do
  • Country: gr
« Reply #2 on: August 07, 2010, 01:29:36 pm »
Thank you for your reply.
Could you elaborate or give an example?
Offline Valhallasmith
« Reply #3 on: August 07, 2010, 04:44:09 pm »
Well, are you going to do anything that required hot air?  Typically this means small pitch items with hard to get at pads.  Like small chip scale packages.
Offline Zyvek
« Reply #4 on: August 07, 2010, 05:01:55 pm »
I have an all-in-unit that is similar, and it also has a desoldering gun.
http://www.circuitspecialists.com/prod.itml/icOid/9766
Not a bad deal, and if you are short on bench space they reduce your foot print.  I've done SOIC, with the iron and SMT with the hot air gun as well.  They are pretty versatile, and there are a lot of iron tips and air nozzles available, including SMT tweezers (I haven't bought one of those yet, but it's on the wish list).
The big downside is if the machine goes down you might be totally out of luck vs. having separate machines
FWIW
-Z
  • Country: gr
« Reply #5 on: August 08, 2010, 08:20:57 am »
For now I don't have any specific task which requires hot air. I think of buying the rework station so I won't have to buy another hot air station in the future if I need it...
Offline EEVblog
« Reply #6 on: August 08, 2010, 08:37:13 am »
Aoyue aren't exactly a good brand name iron.
I'd get a good brand name iron (Hakko, Weller, Pace, Ersa et.al) and an el-cheapo hot air unit.
You use the iron all the time, so it's important to get a brand name one I think.
Hot air less so, so a one-hung-low brand should do fine.
Dave.
  • Country: gr
« Reply #7 on: August 08, 2010, 07:30:17 pm »
Thank you all for your answers.
I found the aoyue 968 at ebay with 200$ including shipping costs.
Which other soldering station would you suggets?
Offline EEVblog
« Reply #8 on: August 08, 2010, 10:52:15 pm »
The classic Hakko 936 is $84 with free shipping.
Available from Amazon (see my store www.eevblog.com/amazon) or a million other places.
Dave.
  • Country: gr
« Reply #9 on: August 09, 2010, 07:38:48 am »
Thank you very much Dave,
the problem is that I live in Greece and Amazon does not ship any electronic equipment there. I found hakko 936 at ebay and it's 50$ cheaper than Aoyue 968 (including shipping), that's why I am asking if it is worth to pay 50$ more for a 3in1.
I also found out that Hakko 936 is discontinued(Hakko FX-888 is its successor), will there be any problem with that? (for example not enought tips, support etc)
« Last Edit: August 09, 2010, 07:50:45 am by ShadowReaper »
Offline DJPhil
« Reply #10 on: August 09, 2010, 08:31:55 am »
I'd say it really depends on how much hot air work you plan to do. I was facing a similar choice a while back and decided that I'd get the 936 and fish around later for hot air and vacuum tools if I needed them. In my case it proved to be the right thing to do, as I've learned to solder and desolder (with wick and two different sizes of hand held vacuum) well enough to do the larger surface mount stuff with just a small tip. If you're trained and used to hot air, or you plan to need it as much as you need a regular iron, then it might be a good call. I actually spent as much on my first batch of supplies (good solder sucker, solder, a larger and a smaller tip, liquid flux, flux pen, desoldering braid, and more) as I did on the 936 itself, and I think it made a huge difference in how fast I learned.
I checked Hakko's site and they're not cross compatible, which was a bit of a surprise. It's likely that you'll be able to find parts for several years to come, as the 936 has been a production iron in Asia and across the world for . . . something like a decade or more? Hakko's manual lists part numbers for every washer, bolt, and plastic doohickey for the iron, and there's a lot of inventory out there. I'd recommend avoiding the no-name brand tips if you can, I'm not sure I'd trust them the way I treat tips.
The FX-888 looks like the direct successor as ordained by Hakko, and is likely an excellent investment. I'm very impressed with their design and support, and I'd recommend either one to someone starting new. A soldering iron is part of my holy trinity of electronic tools along with a scope and a meter, and I'd recommend spending the extra cash for quality, single purpose iron. Of course, this is just my opinion.
Hope that helps. :)
Offline EEVblog
« Reply #11 on: August 09, 2010, 12:54:45 pm »
The 936 and before that the identical 926 (just older styling) have been an industry standard for at least 20 years now I think. I think I bought my 926 circa late 80's IRRC. Apart from maybe the Weller's I'd say it's the widely sold solder station in the world. So you can expect tips and parts to be around for a long time I suspect.
I don't know why the new 888 is not backward compatible, that seems crazy.
Dave.
Offline kaptain_zero
« Reply #12 on: August 17, 2010, 03:06:43 am »
Weird, I just saw this post and had to check it out before I spring for a 936-12 in Canada... it's on sale right now for $89.40 CDN which is a pretty good deal locally(sorry Dave). There is no indication from Hakko NA that the 936 is discontinued and even if it is, I would expect parts to be available for quite a few years, otherwise it would be to Hakko's detriment, as nobody is going to purchase new equipment from a company that doesn't support it's older, yet still serviceable equipment.
Regards
Christian
Offline exodia
« Reply #13 on: August 19, 2010, 08:56:18 am »
Sorry for hijacking the thread.
I'm in a search for a soldering station my self. I leave in Greece and we have 220 V mains so all the hakko's i found on ebay are sadly for 110v. Any other alternatives? I would like a digital temperature setting, also i would like to do my first SMD soldering desoldering with that
Offline djsb
« Reply #14 on: August 19, 2010, 11:32:47 am »
Buy a step down transformer. There must be a company in Greece that makes them. I've just bought a Pace station from the USA and it will cost me around £40 for a 500VA transformer.
http://www.airlinktransformers.com/transformer/us05011-500va-american-120volt-transformer.asp
David.
« Last Edit: August 22, 2010, 06:49:04 pm by djsb »
Hertfordshire, UK
University Electronics Technician, London, PIC16/18, CCS PCM C, Arduino UNO, NANO,ESP32, KiCad V8+, Altium Designer 21.4.1, Alibre Design Expert 28 & FreeCAD beginner. LPKF S103,S62 PCB router Operator, Electronics instructor. Credited KiCad French to English translator
Offline McPete
  • Layout Designer, AKA eCAD monkey
« Reply #15 on: August 21, 2010, 12:40:25 pm »
I'm a Hakko Fan, and yeah, most of the ones avalible internationally are US 110V (no good for for me either; Australia is at 240V/50Hz). My leaning would be toward this;
http://www.tequipment.net/WellerWESD51D.html
This one looks nice, but the iron tips are expensive;
http://tequipment.net/WellerWSM1.html
Given an open budget though, a Hakko 702B or a JDC Nano system would be awesome :P
Offline Ronnie
  • Country: ph
  • Stimulating your Ears
« Reply #16 on: September 23, 2010, 05:10:17 am »
I'm also considering the Weller WESD51D since I live in the Philippines where electricity is 220V/60Hz. Its digital temperature readout is a good feature.
http://www.alliedelec.com/search/productdetail.aspx?SKU=9843988
Hakko FX-888 (replacement for Hakko 936) is nice but I'm not sure if there is a 220V/60Hz version. Take note that FX-888 is not available in North America.
http://www.hakko.com/english/products/hakko_fx888.html
Offline Hypernova
  • Country: tw
« Reply #17 on: September 28, 2010, 07:51:51 am »
Check out my unboxing of this interesting piece of kit:
https://www.eevblog.com/forum/index.php?topic=1287.0
Offline sonicj
  • updata successed!
« Reply #18 on: September 30, 2010, 06:20:07 am »
aside from $35, im not seeing the difference between the wesd51 and wesd51d....
http://www.tequipment.net/WellerWESD51.html
anyone know?
« Reply #19 on: September 30, 2010, 06:27:53 am »
Looks like the difference is that the 51 is a 120v unit, and the 51d is the 240v version.
Regards
Christian
anyone know?
Offline Ronnie
  • Country: ph
« Reply #20 on: October 05, 2010, 12:24:47 am »
WESD51 is 120V 60Hz and WESD51D is 220V 50/60 Hz as can be seen from this link http://www.cooperhandtools.com/onlinecatalog/Parts_Lists/WESD51_OI_PL.pdf
What about the Hakko FX-888 Aus/NZ model sold in Australia and New Zealand is it specified to work at 220V 60Hz electricity? I believe Australia and New Zealand are both 230V 50Hz.
http://philippines.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=6803464#header
If FX-888 Aus/NZ model is only 50Hz then I'll get the Weller WESD51D for US$180.60 (+ US$12.34 shipping) at http://www.tequipment.net/WellerWESD51D.html
In terms of temperature stability FX-888 is ±1°C better than WESD51D ±6°C.
Offline exodia
« Reply #21 on: October 27, 2010, 05:23:47 pm »
What do you guys think about Hakko FX 951 from IPmart
http://www.ipmart.com/main/product/High,Quality,HAKKO,FX,951,Lead,Free,Digital,Display,Constant,Temperature,Soldering,Station,220V,,271000.php?prod=271000
BTW ip is reliable, anybody that have traded with them?
Offline SuperMiguel
« Reply #22 on: October 29, 2010, 01:21:17 pm »
Regards
Christian
anyone know?
digital display
