Author Topic: LFS: HP/Agilent/Avago HDSP-6653 LED Displays or equivalent  (Read 1879 times)
Offline mickcTopic starter
« on: July 24, 2017, 12:48:12 am »
As the title suggests, im looking of 6x HDSP-6653TXV  displays or just HDSP-6653 - Datasheet attached
These are 4 digit, 5x7 LED matrix, 5mm Character height, Green LED displays.
Originally made by HP, then listed with Agilent as per attached datasheet, now new listings show as Avago as they bought the Agilent Semi business.
They show as no longer manufactured, but I am looking for any potential old stock anywhere.
They do not have to be the exact model, as long as the main specs if 4 digits, 5x7 matrix as close to 5mm height as possible, and must be green.
These were initially used in the electrical metering panel of the Boeing 737 overhead panel, and they will be used in a flight simulator.
Thanks in advance for any ideas or pointers in the right direction.
Cheers.
Offline edavid
Re: LFS: HP/Agilent/Avago HDSP-6653 LED Displays or equivalent
« Reply #1 on: July 24, 2017, 05:29:41 pm »
You could use HDSP-2303 if you don't mind implementing your own display driver.
http://www.dhgate.com/store/product/hdsp-2303-5x7-dot-matrix-display-high-performance/389050863.html
You might get a better price from utsource.net
Or you can see if any of these are left, but they are 4mm high:
https://www.eevblog.com/forum/buysellwanted/(fs-world)-hp-hdsp-2000-green-yellow-led-matrix-displays/msg1165271/
« Last Edit: July 24, 2017, 05:32:01 pm by edavid »
Offline CJay
« Reply #2 on: July 24, 2017, 06:36:23 pm »
Locaton might be useful information.
HDSP2001 is roughly the right size but uses a serial protocol, if they look suitable then Dexterslab2013 had a few.
« Reply #3 on: July 25, 2017, 01:27:41 pm »
Thanks Gents,
I am located in Australia.
Those HDSP-2303s look like they will do the trick, DHGate only have 2, but i will try and see if I can track more down.
Unfortunately the 2001s that Dexters lab has/had are too small for the application
Offline JimmyJo
  • Country: hk
« Reply #4 on: July 28, 2017, 02:39:59 pm »
What about the HDLG-2416, plastic package, but cheaper than the hermetic ones.
« Reply #5 on: August 01, 2017, 10:58:11 am »
Cheers JimmyJo
They look like they will do the trick!  Easier to interface with Arduino than the originals too.
Thanks guys.
