I should mention that this is for work. The majority of this work is repairing and modifying old boards and implementing Engineering change orders on boards already out in the field. I am putting this together so that when the boss asks me, the guy that knows which end of the soldering iron not to touch, what can we do to meet these increasing capability needs i have something that while not perfect would after a few tweaks be "shovel ready"
The room this is going to be in is roughly 13' by 15' a few more inches might be available if we take down the internal walls and noise blocking insulation and go back to bare cinder block-not my choice considering the noisy area just outside. Currently it has 2 flat benches with no storage above or below, a desk, a Kennedy locker, and 3 shelving units that store items for another area. One bench is dedicated to a functional test fixture for the primary contract I work on which has about another year to go. I am also starting to work on another contract that will also require some dedicated bench space and a lead free soldering station which we currently do not have.
I want to arrange them into work-cells so the testing and troubleshooting happens in one cell and the incoming inspection, documentation, cleaning, stripping, rework/rebuild, and final inspection functions happen in the other.
Soldering work-cell would be one corner bench with leaded soldering on one side, thinking a Pace PRC-2000 on that side to give us coverage to properly rework some of the nasty chewing gum and bailing wire type repairs I have seen come through. The lead free side would have a PACE MBT-350. Have a Mantis with a digital camera or a Targano scope in the center for inspection and or documentation of visible damage. re-purpose one of the current benches to hold an ultrasonic cleaner and a micro-sandblaster system for stripping the boards. one wall is on the exterior of the building so ventilation would be relatively easy to get set up with and ERV system.
Test-cell wise I am going to need a bench or 2 to hold various special purpose test fixtures we get in from customers, build ourselves or get in from the Engineering centers my employer has. I am hoping to be able to acquire an S500 and or a Pinpoint system with an Autopoint DT flying probe/ASA test system from Diagnosys to handle the majority of the testing and troubleshooting requirements in a relatively small footprint.
If i can squeeze a small thermal chamber in there I will.
