Author Topic: Has anyone heard of the Solderlene flux?  (Read 1841 times)
Offline imgTopic starter
« on: March 31, 2013, 10:35:26 am »
If you or your colleagues have used Solderlene, please post impressions/reviews.
Offline nanofrog
Re: Has anyone heard of the Solderlene flux?
« Reply #1 on: April 01, 2013, 12:03:32 am »
If it's what I think it is (http://www.highsidechem.com/solderlene.html), it's made of zinc chloride and ammonium chloride, which is what would be used for things such as plumbing.
Do not use this type of flux chemistry for electronics (will cause corrosion in your joints, and can damage unprotected traces). Use a Rosin based or No-clean organic flux instead (water clean will cause corrosion if not cleaned off in time <measured in hours>, so I'd stay away from this as well).
« Reply #2 on: April 02, 2013, 07:29:45 pm »
Myeah, I found the manufacturer's site too.
Fishy stuff.
OK, back to old favourites!  >:D
