Lodestar 8230 Laboratory Linear Power Supply
$300 AUD
- 3 outputs:
- 0-30v / 3A x 2
- 5V / 3A x 1 (fixed output)
- Primary and secondary outputs can operate in independent or tracking mode to double output or voltage to 60 V / 6 A.
- Internal digital voltage meter can operate independently from the power supply with external probes.
- Channels 1 & 2 can operate as constant voltage or constant current mode.
Well cared for and has just had the main power transistors, all capacitors and bridge rectifiers replaced. Supplied with manual and circuit diagrams. Located in Sydney- can post at buyers expense.
