Author Topic: FS Working Systron Donner M107 precision voltage source + manual PRICE CHANGE!  (Read 1308 times)
Offline 5065AGuruTopic starter
Hi, Cleaning out my lab and getting rid of this unit. 1V/10V/100V/1000VDC F.S. 0-50 mA adjustable constant current. Only problem is that the sequence LED does not light when sequence is selected. It does go into sequence and works properly, just the indication is bad. I have tested against my HP3456A which has NOT been recently calibrated so it could probably benefit from calibration from a known good source.
Uses an LM299AH as its reference.
Complete manual include schematics, operations, theory, alignment, parts lists, and maintenance info.
Ships to USA only 24"X21"X14" 43Lbs.
If you have a UPS or FedEx account shipping would be cheaper if you sent me a shipping label for the box. $250.00 + shipping.
Price dropped to $175.00
Cheers,
Corby
« Last Edit: July 04, 2024, 11:34:55 pm by 5065AGuru »
Bumped to change price!
Online Stray Electron
  Where are you located and can you tell me roughly what the shipping would be?
I'm in Lompoc, CA.
The box will be 24X21X14 and will weigh 45 pounds.
If you give me your address I can determine the shipping amount.
Cheers,
Corby
Bumped with a new price!  :)
