Up for sale is a classic Power Designs precision supply from the mid-1970’s. The heart of the supply is double oven that contains a hand binned zener reference and discrete transistor amplifier. Two sets of custom inner-outer switches allow selection from 0 to 39.990 volts, with an additional 10-turn pot that acts as a 0 to 10mV vernier, which allows setting the full scale voltage at a microvolt level. Current limiting from 0 to 1A is provided by a 3/4 turn pot. Three status lamps indicate oven, power and current limit status. The oven runs full time when plugged into AC, allowing instant precision use with no warm up. Voltage and current is shown on a Yokogawa edgewise meter.
I’ve taken the entire unit apart, cleaned it, checked all the electrolytes, replaced all three lamps with brand new orange neon units. I also took apart the pots, scrubbed them clean and applied DeoxIT Fader Lube. The switch array had the same treatment, only with DeoxIT Shield applied to the contacts and white lithium grease to the ball bearings and moving parts. I also repainted the case inside and out then added brand new fasteners.
Finally, I performed a voltage and current calibration on it. This thing is super stable! I can actually slowly move the mV knob and change the voltage in uV steps. And once warmed up, the voltage holds perfectly steady, only varying a hundred nV up and down as the oven turns off and on. This would make a great supply for anyone wanting to add a little precision to their lab.
I’d like to get $175 shipped (to the US; I’ll ship international but buyer pays any additional shipping costs over the first $25).During Restoration:
