Author Topic: FS: HP 54120A/54121A Digitizing Osciloscope 20GHz working condition (EU)  (Read 889 times)
Offline Rob434Topic starter
HP 54120A Digitizing Oscilloscope Mainframe with HP 54121A Four Channel Test Set
The unit is good condition. There are visible scratches and signs of wear from normal use. The two of the plastic legs that are used to place 54120A in upright position (screen facing up) are partially broken so placing it in this position is not advised. There are signs that the blue warranty stickers on the back have been renewed over the years due to regular maintenance but it is hard to say if the newest ones have been broken or not but they look largely intact. The unit has been mostly unused for several years so the following tests and checks were done:
Display on HP 54120A works
Power-up self test pass
All buttons on HP 54120A front panel work
All input channels (1-4) and trigger input on HP 54121A work
Measured voltage and pulse width for known pulse signal are correct (setup as described in "54120 Series Digitizing Oscilloscope Getting Started Guide" page 2-1)
No other tests or measurements have been done with this unit. Can send more images if needed.
The total weight of the set packaged is about 25kg. Buyer pays shipping costs. Will ship to anywhere in EU. Payment can be done via PayPal.
Price: 1900 EUR
Also accepting offers. I also have HP 54118A trigger module that can be added for extra cost. PM for details.
« Last Edit: August 21, 2022, 02:43:58 pm by Rob434 »
Offline coromonadalix
hum  some of your images are inverted ...   :-+
« Last Edit: August 21, 2022, 06:01:16 pm by coromonadalix »
Ah yes. Exif metdata was apparently ignored. Now it is fixed. :)
