Author Topic: FS: Binding posts used in µCurrent GOLD  (Read 3811 times)
Offline iloveelectronicsTopic starter
  • Country: hk
« on: April 10, 2014, 05:05:41 pm »
As some of you may know, I helped Dave source the binding posts used in his µCurrent GOLD. I finally got around taking a few pictures of them so here I am offering them for sale. These are the exact same binding posts you see in Dave's µCurrent GOLD.
$4 for the first pair and $2.5 per additional pair, worldwide shipping included (no tracking). Tracking is an additional $2.4 per shipment if you need it.
Please PM me if interested. Thanks for looking!
Cheers,
Franky
P.S. I have asked Dave for permission to mention "µCurrent GOLD" :)
« Last Edit: March 01, 2016, 10:34:42 am by iloveelectronics »
My email address: franky @ 99centHobbies . com
My eBay store: http://stores.ebay.com/99centhobbies
Offline BravoV
  • +++ ATH1
Re: FS: Binding posts used in µCurrent GOLD
« Reply #1 on: April 10, 2014, 05:09:59 pm »
Just a testimony, bought few sets of these from Franky too after knowing Dave sourced it from him, shipped and delivered pretty fast, recommended.  :-+
Offline electr_peter
  • Country: lt
« Reply #2 on: April 10, 2014, 06:23:45 pm »
Hi, Franky,
I would like to put those binding posts in a panel. However, there is limited space behind panel to fit binding posts, 9-12 mm. I would like to know the length of protruding part with screw (assume that you would mount these post on very thin panel - what would be protrusion from the back?)
Can you post detailed dimensions of these posts?
Edit:
PM send
« Last Edit: April 11, 2014, 11:50:21 am by electr_peter »
Offline Vgkid
« Reply #3 on: April 10, 2014, 08:20:46 pm »
Can I get some specs for those, if it doesn't bother you.
  • Country: hk
« Reply #4 on: April 11, 2014, 02:08:44 am »
Hi, Franky,
The mounting key protrudes about 2mm, and then it's about 9mm to the end of the screw.
A few other dimensions: The hole has a diameter of about 5.2mm, the cap on the front has a diameter of about 11.6mm and length of 15.2mm. Diameter of the screw is 3.8mm. The mounting key is about 4 x 5.4mm.
Offline Vgkid
« Reply #5 on: April 11, 2014, 02:13:02 am »
What are they made of?
  • Country: hk
« Reply #6 on: April 11, 2014, 02:15:23 am »
There actually aren't a lot of specs given to my from the supplier, apart from the dimensions I posted above. The materials used on the binding post and the soldering tab are indicated as gold plated copper, while the washer and nut are gold plated iron.
Offline yo_nutz
« Reply #7 on: February 27, 2017, 10:46:31 am »
Do you still have them for sale?
I would be interested to purchase.
