https://www.ebay.com/itm/166812192407?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=CTI57OxBQDq&sssrc=2047675&ssuid=CTI57OxBQDq&widget_ver=artemis&media=COPYWhat this is:
This is a Tektronix Type 191 Constant Amplitude Signal Generator that has a bandwidth of 50kHz and 350kHz to 100MHz. It can output these frequencies at calibrated amplitude steps.
The GR-874 to BNC adapter will be included.
Condition:
The condition on this unit is good. There are a few scratches here and there, but otherwise okay. See images for more details.
The unit has been tested with a calibrated 7904 mainframe using a 7A19 and 7B85 plug-in. All tests yielded results indicating normal operation. See images for more details. Also, yes, the 7904 scope is calibrated. The "Out of Service" sticker was a reference to my ebay username & profile icon.
Some low voltage capacitors have been replaced.
Important Notes:
The potentiometer that regulates the -11v rail has been replaced with a trimmer potentiometer by me. The original pot had seized up and would not turn even with penetrating spray, heat treatment, brute force, and other methods. So I simply replaced it. The new tiny pot should be replaced though as it is not quite suited for the job. I used this tiny pot because it was the only value potentiometer that would suit the needs of the 191. Also, I couldn't quite bother finding an actual replacement. It's been like this for over a year and seems to be doing just fine as is. The temporary solutions tend to be the most permanent ones.
Questions?:
Please feel free to ask away- even if it seems sort of stupid. I will try my best to answer them.
