HP 3455A VoltmeterPhotos below
Asking US$150 + shipping
Fantastic condition, accurate HP reference voltmeter. Good condition, front panel & rear panel flawless. Case top & bottom have a few dents, nothing affecting performance. Tested with DMMCheck Plus, has less than 0.09% across all measurements, DC voltage within 0.04% and 10kOhm within 0.0008%. Operational verification test results will be included (see last photo for a copy), but YMMV.
DescriptionHewlett-Packard's 3455A Digital Voltmeter is a 6 1/2-digit (7 1/2 available through GPIB) integrating voltmeter for bench or systems applications. The standard instrument measures dc volts, ac volts, and resistance. HP-IB and auto or manual ranging are also standard.
The HP 3455A is fully guarded and has greater than 60 dB normal mode noise rejection at reading rates of up to 24 readings per second on all dc ranges. Ohms reading rates are up to 12 readings/second and an ac fast mode gives reading rates of up to 13 readings/second at frequencies above 300 Hz. (Readings/second given for 60 Hz operation and high resolution off.)
DC measurements can be made with up to 1µV sensitivity. Ohms measurements are made with either a 2-wire or 4-wire mode. The high resolution (6 1/2-digit) mode gives dc and ohms measurements with greater than 1 part per million resolution. The standard true rms ac to dc converter measures sinusoid and complex signals with crest factors up to 7:1 at full scale from 30 Hz to 1 MHz.
Comes with power cord, no leads.
ManualsOperating Manual -
http://www.home.agilent.com/agilent/redirector.jspx?action=ref&cname=AGILENT_EDITORIAL&ckey=818470&lc=eng&cc=US&nfr=-536900193.536897073.00Service Manual -
http://www.home.agilent.com/agilent/redirector.jspx?action=ref&cname=AGILENT_EDITORIAL&ckey=722586&lc=eng&cc=US&nfr=-536900193.536897073.00EEVblog Teardown -
https://www.eevblog.com/forum/testgear/hp-3455a-teardown/Shipping & PaymentNote - heavy large item so shipping will be more expensive. Ships via FedEx, located in San Francisco, California, USA.
Payment via PayPal or cash if it's a local pickup.
WarrantyGuaranteed not DOA - return shipping is the responsibility of the buyer.
About the SellerI've been lurking on EEV for some time, although I've only posted recently. I've got way more gear than I can use, the result of a spending spree over the last few months, so I need to offload some stuff. I also have this up for slightly more on eBay, but I'd prefer a direct sale. I'm locate in San Francisco, California, USA and if you want more info please PM me.
