Author Topic: SOLD (EU): Keysight DSO6104L 1GHz LXI scope (used)  (Read 3366 times)
Offline NeganurTopic starter
« on: February 24, 2018, 11:55:56 am »
Datasheet: http://literature.cdn.keysight.com/litweb/pdf/5989-5470EN.pdf?id=875632
Up for sale is another very nice 1 GHz 4GSa/s 8MPts rack oscilloscope of the 6000-series.
Good condition (some scuffs, left rack ear is bent), Options:
mem8M - 8/4 Mpts of sampling memory (8 for 2-ch pair, 4 all analogue channels on)
MST - measurement statistics, cursor waveform tracking
E00 - enhanced trigger types (FlexRay), Lister
Works fine using an external monitor and java/VNC webcontrol.
  • 1 GHz, 4 analog channels, 4 GSa/s, 8 MPts memory, 100,000 wfms/s
  • Autoprobe interface for e.g. N2795A active probes
  • 1U-high 19-inch wide package (ca. 435x230x45 mm)
  • Full connectivity with USB, LAN, GPIB interfaces and XGA out
  • 16 digital channels with MSO option
no accessories, just the scope unit.
1600 EUR incl. insured courier shipping within EU, SEPA preferred.
« Last Edit: February 24, 2018, 01:56:58 pm by Neganur »
Online Zucca
  • EE meid in Itali
Re: FS (EU): Keysight DSO6104L 1GHz LXI scope (used)
« Reply #1 on: February 24, 2018, 01:24:24 pm »
Nice, will the 1152a work with this one? Sorry for being so lazy I am at the restaurant don't have time to look it up
« Reply #2 on: February 24, 2018, 01:37:12 pm »
Not unless you modify the probe's power supply
(it wants 4V if I recall correctly and the 6000-series has the new interface that can only provide 5V)
Online Zucca
  • EE meid in Itali
« Reply #3 on: February 24, 2018, 01:41:15 pm »
Well sold, pm me your bank account.
Online Zucca
  • EE meid in Itali
Re: SOLD (EU): Keysight DSO6104L 1GHz LXI scope (used)
« Reply #4 on: February 24, 2018, 11:29:35 pm »
Another line in my todo list:
https://www.eevblog.com/forum/testgear/agilent-1152a-active-probe-%27smartprobe%27-conversion-for-dsox3000-series-scopes/
Online mk_
  • Country: at
« Reply #5 on: February 25, 2018, 09:28:02 am »
Nice scope,
using the scope with java/VNC inside a browser is tricky as most browsers do not accept java as plugin anymore.
if this is solved - really a fine instrument
Michael
Offline BravoV
  • +++ ATH1
« Reply #6 on: February 25, 2018, 12:01:27 pm »
It can be solved easily, its called OS encapsulation, aka virtual machine.  :P
Online mk_
  • Country: at
« Reply #7 on: February 25, 2018, 01:06:38 pm »
I shall install a VM to use an outdated browser to use a oscilloscope via LAN? Really?
Well, sounds a little bit to complicated for me... (I tried but... no luck as I had no older java and to register at oracle just to download an older... no)
The guy who found an easier way or I will post a how too in the next days :-)
michael
« Last Edit: February 25, 2018, 01:08:58 pm by mk_ »
Online Zucca
  • EE meid in Itali
« Reply #8 on: February 25, 2018, 05:40:05 pm »
Unfortunately I will be in USA for the next two months so I don't k own if I will have time to play enough with this new toy.
Here my game plan:
- use RealVNC
- external monitor, raspberry pi to control somehow?
- use an old  XP laptop i have under my desk
« Reply #9 on: February 26, 2018, 07:02:19 am »
just register on Oracle's website with a throwaway email, download the older java and modify the security settings like you would for any other popup/trusted site.
Once that's done it's really not so much of a problem, and I even just placed a shortcut on the desktop to go straight to the vnc session:
"%ProgramFiles%\Internet Explorer\iexplore.exe" "http://192.168.1.203/remoteFrontPanel.html"
I'm sure there are other solutions but this one worked for me (the PI thing sounds cool,  the scope has USB too so I see no reason why it shouldn't be possible to write some small program that replaces the missing front panel)
Offline Mr. Scram
  • Display aficionado
« Reply #10 on: February 26, 2018, 10:52:41 am »
michael
It sounds complicated, but if you have any experience with VMs it's really not. Having a perfectly controlled and isolated environment to run outdated software, which can be modularly added or removed is pretty much ideal. With some care you can do things that would normally be quite risky without consequences for the rest of your infrastructure.
