Author Topic: FS: (CAN) NEW Metcal/OKI Soldering Cartridges/Tips $7  (Read 1321 times)
Online macboyTopic starter
« on: May 27, 2016, 04:32:23 pm »
I have several brand new, never used cartridges for Metcal/OKI irons. These are all for MX series handpieces, and are all "700 series" for "standard applications" including lead-free. I recently bought one of these irons (and now I know what all the fuss is about - WOW), and bought these cartridges with the iron. However, I find that I prefer the 600 series "temperature sensitive applications" ones for my work, which is almost exclusively using lead based solder. I find that the 700 series are just too hot for my liking, but they are the most common ones sold and are the ones recommended for lead-free so I figure someone here must want them.
I have listed prices below, but I am also willing to trade 2 to 1 or similar new 600 series tips (I'll give you two of these for your one), or a straight swap for a gently used 600 series one. A 600 series will have a leading 0 instead of a 1 in the numerical portion of the part number (e.g. STTC-045 rather than STTC-145). For a  swap, we would each pay shipping on our end. I am located in Canada, postal code K2J4W8.
STTC Series soldering tips. Remaining tips are USD$7 each (minimum of two please)
STTC-101 - 1.0 mm conical - large quantity available
STTC-101P    - 1.0 mm conical, shortened for higher heat transfer, designed for lead-free - large quantity available
STTC-165 - large 5mm chisel
STTC-125
STTC-145 (x 3)
STTC-146
STTC-199
SMTC-1174  - small 'hoof' for drag soldering. USD$15
To the above, add +$5 for shipping within Canada/USA or +$8 internationally, for any quantity.
I may be able to acquire additional quantities of some of those, and limited additional varieties as well. The attached Metcal datasheet covers all of the above tips.
Edit: clarified prices, shipping cost, quantities.
« Last Edit: May 30, 2016, 03:28:16 pm by macboy »
Offline daddylonglegs
Re: FS: (CAN) NEW Metcal/OKI Soldering Cartridges/Tips
« Reply #1 on: May 27, 2016, 05:48:04 pm »
PM'd re 1174, 125 and 199.
Re: FS: (CAN) NEW Metcal/OKI Soldering Cartridges/Tips $10
« Reply #2 on: May 28, 2016, 12:04:45 pm »
Some are sold, as updated above.
