Author Topic: FS (Brisbane, AU) Charmhigh CHMT48VB Pick and Place  (Read 529 times)
Offline deanclaxtonTopic starter
« on: July 13, 2024, 09:40:13 am »
Charmhigh CHMT48VB pick and place machine. Great condition and includes a custom cover.  Low usage and comes with spare nozzles etc. Asking $5000 ONO
Pickup Milton QLD 4064.
Contact me for further info.
Offline Shock
Re: FS (Brisbane, AU) Charmhigh CHMT48VB Pick and Place
« Reply #1 on: July 14, 2024, 01:52:14 am »
I met Dean in about 2019 and brought some enclosures off him, a nice bloke.
If you are in the market for a machine you should go check it out.
The following users thanked this post: deanclaxton
« Reply #2 on: July 14, 2024, 03:48:43 am »
This is the machine. I'll get some better photos of it tomorrow along with the usage counter.
The computer is built in on this model, as is the vaccuum pump so you dont need a compressor or anything else.
It has 2 nozzles, 44 x 8mm, 8 x 12mm, 4 x 16mm and 2 x 25mm drag feeder slots.
Selling due to upgrade to a larger machine with more feeders. This one honestly worked great - I was always surprised just how well the drag feeders work. We were placing 250+ components (passives were 0603) on a small panel mostly without stoppages. If it did stop it was usually due to a cover tape spool tension needing adjustment, but it didnt happen that often and was quick to rectify.
« Last Edit: July 14, 2024, 04:00:52 am by deanclaxton »
