Author Topic: Free three channel power supply 2x30V + 5V  (Read 2563 times)
Offline Back2VoltsTopic starter
« on: January 31, 2019, 01:14:42 am »
I got this power supply from a failed automation lab in the area.    I have used it very little.   It is a MASTECH HY-3003-3.  Heavy as a truck.
Let's start with free to anyone in the central Minnesota area.
Re: Free three channel power supply 2x30V + 5V
« Reply #1 on: January 31, 2019, 06:00:22 pm »
Attached picture.   I have a manual I found years back, but it exceeds max size.  If interested send me text message with email and I will forward it.
I think this is it http://hades.mech.northwestern.edu/images/f/f7/Mastech_power_supply_manual.pdf
« Last Edit: February 01, 2019, 04:00:46 am by Back2Volts »
Offline pbarton
« Reply #2 on: February 01, 2019, 12:04:26 pm »
That bears a striking resemblance to a Tektronix PS280 power supply.
Offline JVR
« Reply #3 on: February 03, 2019, 05:17:51 pm »
What would postage to Belgium be like?
Offline tsman
« Reply #4 on: February 03, 2019, 05:39:00 pm »
That wouldn't be cheap. The manual says it is approximately 10kg just for the PSU.
« Reply #5 on: February 04, 2019, 08:51:56 pm »
I weighs around 23 pounds.    I suspect you could get a new one for what you would be paying for packing/shipping.
« Reply #6 on: February 04, 2019, 08:54:19 pm »
Any one interested in or around the Twin Cities?   I will be going to the cities in a couple of weeks.
Online Doctorandus_P
« Reply #7 on: February 04, 2019, 09:19:39 pm »
I always had my suspicion that Tektronix was just rebranded Chinesium.
Offline richnormand
« Reply #8 on: February 04, 2019, 10:19:31 pm »
Or the other way around?
Would be nice to see the insides.
Things like the filter capacitors values and brands, stability feedback, overload protection (note front panel of Tek), etc...
Repair, Renew, Reuse, Recycle, Rebuild, Reduce, Recover, Repurpose, Restore, Refurbish, Recondition, Renovate
Offline eponte5
« Reply #9 on: February 05, 2019, 05:51:50 pm »
Funny, I have that power supply as a GW Instek GPC-3030D.
The overload LED is if you push the 5V past 3A it lights up.  (since there is no meter attached to it, it's the only indication for the 5V.)
The bad part about this supply (which I learned the hardway) is the manual states that using it in parallel or series they recommend actually physically attaching wires after setting the buttons.  If you don't, it can damage the unit if you push the supply too hard through the internal series/parallel connections.
*******(I just saw the same instructions in the Mastech manual in the notes section.)  Take heed to this warning...  It will fry the slave where you loose control of it.  It's on my healing bench to get fixed.....
« Last Edit: February 05, 2019, 06:06:11 pm by eponte5 »
Offline aksg81
« Reply #10 on: March 26, 2019, 01:06:19 am »
Hello, I'd be willing to take it and put it to good use if its still available.
I'm at the UofM in Minneapolis.
Offline jlmoon
  • If you fail the first time, keep trying!
« Reply #11 on: March 27, 2019, 02:23:12 am »
If aksg81 doesn't want it, I do.
In Fort Worth, Texas.  76180
Recharged Volt-Nut
