Author Topic: Broad Band X-Ray Telescope (BBXRT).  (Read 3450 times)
Offline firewalkerTopic starter
  • Country: gr
Re: Broad Band X-Ray Telescope (BBXRT).
« Reply #1 on: April 14, 2012, 01:59:47 pm »
Note that delivery outside the US of A would be subject to ITAR regulations. Shipping would be a bit pricey as well.
Offline Spawn
  • ³²µ º'ºººº³²
« Reply #2 on: April 14, 2012, 02:07:02 pm »
If you lend me the full price SeanB i will cover the shipment  ;D
« Reply #3 on: April 14, 2012, 02:28:28 pm »
Will you take Zimdollars? I might have enough in them.
Anyhow, as you live in Der Nederlands, you would just get a container filled with concrete.
Offline AntiProtonBoy
  • I think I passed the Voight-Kampff test.
« Reply #4 on: April 14, 2012, 02:46:26 pm »
That would be an awesome gear to own. I'd buy it, if I had nothing better to spend my money on, and see if I could get it up and running.
« Reply #5 on: April 14, 2012, 03:13:31 pm »
It probably still works, as it was designed for use in a shuttle bay, so would only need power supplied via an umbilical. Probably the computers that run it are missing, as they were standard Shuttle computers ( IBM 360 derivatives) and would have been robbed as spares and replacement parts. The reflector and such are probably OK, but you would need to have a few litres of liquid Helium to operate the detectors.
Offline Spawn
  • ³²µ º'ºººº³²
« Reply #6 on: April 14, 2012, 03:49:36 pm »
Lol, than i would have something to throw at some people  ;D but i am not sure if Zimdollars cover it, let me contact the seller!
Offline G7PSK
  • It is hot until proved not.
« Reply #7 on: April 16, 2012, 08:11:51 pm »
Would you need a big vacuum chamber for it I would imagine that it is designee to work in one and it is quite likely that the sensor needs a vacuum for operation and space would be providing it.
