Heya!!
I am selling a Faxitron DX-50 Specimen Portable X-RAY system (DC12) on behalf of a friend. It was manufactured in 2009 and it has few scratches which is k considering its age. The unit was tested and it’s working as it should. Payment via bank transfer only. The unit is quite delicate so I would prefer collection from High Wycombe. I can deliver locally if needed (Bucks area) at a charge.
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
A 2.5k GBP offer would make me happy. I will also consider other sensible offers.
Included in this sale:
- Faxitron Portable X-RAY DX-50 with Hamamatsu sensor C9732DK
Active Imaging Area: 12 cm x 12 cm
Energy range: 10-35 kV
Tube current: 300 µA
Focal spot size, nominal: <20 µm
Spatial resolution: 10 lp/mm (48um), contact mode
Geometric magnification: None
Window filtration: 0.01" Be, tungsten source
Power: 100-250 VAC, 50/60 Hz, 400 VA
Weight: 25kg
- Dell Optiflex 790 USFF (INTEL I3 2ND GEN 2100 3.1GHz + 4GB RAM + 120G SSD) pre-configured with Win7 and all the necessary software and device drivers for running the X-RAY system. Installation files are also provided.
- Cables: USB + Serial to USB + Power cable for PC and for the MX-20
Any questions? More pics? You can ping me anytime.
