Author Topic: [WTB] Measurement of Capacitors (from Calibrated LCR Meter) [PayPal]  (Read 1831 times)
Offline quantumvoltTopic starter
  • Country: th
I would like to buy measurements at different frequencies / temperatures for some 10 pcs two-terminal ceramic and poly* capacitors ranging from a few hundred pFs to a bit less than one uF. I'll send the caps to you and pay you via PayPal, and you email me the results. [You can keep the caps - I only need a check on my several uncalibrated meters].
Please send PM if and only if you have an upper class LCR meter that has a valid calibration.
Thanks
Roy
