Hi All:
This taught me something new:
https://youtu.be/BnR_DLd1PDINow for modern preamps etc, such as found in video cams....a cellular phone on silent mode (in your pocket or from a bystander)appears to emit an interfering EM squawk when it recvs a msg. This signal can get sneak into the audio recording without you knowing it
![Shocked :o](https://www.eevblog.com/forum/Smileys/default/shocked.gif)
. A live feed picks up the interference.
![Banging Head |O](https://www.eevblog.com/forum/Smileys/default/bangheadonwall.gif)
I was wondering if an exercise to test this might be interesting: enclose the caps in a preamp with foil that is grounded and see if the interference is diminished. One wonders whether there are modern caps with 3 pins...one for a body ground shield/can.
![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
