After tear down, i've done some additionnal pictures...
A new power supply ? (different from Dave MSO5000 review pictures)
![EEVblog #1146 - New Low Cost Rigol MSO5000 Oscilloscope](https://www.eevblog.com/forum/index.php?action=dlattach;topic=149959.0;attach=783978;image)
My new proto airduct
![EEVblog #1146 - New Low Cost Rigol MSO5000 Oscilloscope](https://www.eevblog.com/forum/index.php?action=dlattach;topic=149959.0;attach=783948;image)
Not purple, but green(+9V) and black(GND) (on the second connector, be warning of the second black wire, it's a +7V)
+12V = red(+5V) and purple(-7V)
![EEVblog #1146 - New Low Cost Rigol MSO5000 Oscilloscope](https://www.eevblog.com/forum/index.php?action=dlattach;topic=149959.0;attach=783960;image)
![EEVblog #1146 - New Low Cost Rigol MSO5000 Oscilloscope](https://www.eevblog.com/forum/index.php?action=dlattach;topic=149959.0;attach=783966;image)
![EEVblog #1146 - New Low Cost Rigol MSO5000 Oscilloscope](https://www.eevblog.com/forum/index.php?action=dlattach;topic=149959.0;attach=783954;image)
I've tryed several fans...
- Noctua NF-F12 iPPC3000 PWM (3000trs/min ; 186.7m3/h ; 43.5dBA ; 7.63mm H2O)
- Noctua NF-P12 (1300trs/min ; 92.3m3/h ; 20dBA ; 1.68mm H2O)
Room temperature is 25-26C
The NF-F12 is too noisy even at 9V (analog input front end temperature is 33C)
The NF-P12 is correct at 12V but temperature at analog input front-end reach 40C (instead of 50C)
I'm waiting for another 2000trs/min model.
I've spent lot of time to analyse all heat sources.
I think the back panel and the original cooler system has a design flaw.
There's not a real airflow (left to right or front to back).
I'm trying to develop a simple 3D printed solution (or a cardboard solution) which could be easily build
Rigol> Why not create an efficient airflow ?
![EEVblog #1146 - New Low Cost Rigol MSO5000 Oscilloscope](https://www.eevblog.com/forum/index.php?action=dlattach;topic=149959.0;attach=783972;image)
