First Time measuring at work, spi-decoding….
BIG disappointement…
![](https://i.ibb.co/44R896Q/SPI2.jpg)
It decodes from the screen, what you see is what you get, if not all data are displayed, then you couldn´t see all the data in the event table…..
![ThumbsDown :--](https://www.eevblog.com/forum/Smileys/default/icon_thumbsdown.gif)
Turn one channel off, all data are lost - Lecroy WS3024 and EVEN the smaller, much cheaper siglent 1104 can do it, they decode it from, the memory….and this one do it like the 1054Z
Hope they correct it, so much memory inside and then decoding from the screen....
And:
The event table...You have to turn it on in the menu, good.
But:
If you press the "Back" button or if you turn on another channel, it disappears....
![Roll Eyes ::)](https://www.eevblog.com/forum/Smileys/default/rolleyes.gif)
You have to go back in the menu and turn it on again....
Rigol, please fix it - Event table on/off only when you press the specific button.
And pretty please rigol....decode the data from the memory......PLEASE.
