Author Topic: New Agilent scopes  (Read 385511 times)
Online EEVblog
Re: New Agilent scopes
« Reply #550 on: October 17, 2012, 11:43:48 am »
My reading of that is that only upgrades that go over 350MHz require return - it's not quite clear what is now obsolete
For the 3000X, there are three hardware platform models that share the same hardware:
100MHz and 200MHz
300MHz and 500MHz
and 1GHz is on it's own.
So you can software upgrade from 100 to 200, or 300 to 500, but not from say 200 to 300, or 500 to 1GHz, those require a complete main board change.
So take this into account when buying.
Dave.
Offline elektrinis
« Reply #551 on: October 20, 2012, 10:59:50 am »
So I got the DSOX2004A. Standard package with free DVM and WAVEGEN licences.
I also own an old RIGOL DS1022CD (with LA). Its for sale, BTW (PM me)
When comparing Agilent to RIGOL..
The good:
1. Less fan noise.
2. no bugs so far
3. responsive
4. big screen
5. and all the usual stuff you get for more money.
The bad:
1. Less memory. The rigol has 8 megs. That's a huge downgrade. Can't get used to less memory in agilent.
2. No digital filters?!? C'mon Agilent, really? It's not that cheap to not have this function.
So the questions... Do X2000 series have digital filters for analogue channels? My usual projects require me to have such functionality. It's a bit no-go to use passive filters on leads...
Has anyone figured out the thing with additional 'free' licenses? I would really love having a LA and some serial decoding features. Not paying the big buck of cause.
Offline grenert
« Reply #552 on: October 20, 2012, 08:08:42 pm »
The bad:
Yes, it's kind of incredible that digital filters are only available on the X3000 series (in the Advanced Math option).  There are some obvious software absences on the X2000 series which seem to be in there only to try to justify the much higher price of the X3000 series, since they are widely available on low-priced scopes from other manufacturers.
Offline tom66
« Reply #553 on: October 21, 2012, 12:42:30 am »
The Rigol only has 1Mpt, or 500kpt over two channels. The 2000X starts with 100kpt - in my mind, this is too little for such a nice scope with such powerful display features. Minimum 1Mpt per two channels I think.
Offline ferkapu
  • Country: hu
« Reply #554 on: November 14, 2012, 11:42:12 am »
Still hanging on the firmwares...
I would like to upgarde my 3014A's fw1.20 to newer one, but don't want to loose the trial licenses.
Does anybody have any suggestions, how to do it?
Online EEVblog
« Reply #555 on: November 14, 2012, 11:52:25 am »
We can only hope that as Agilent get more pressure from the likes of Rigol, they will start upping the memory and add the serial decode on the 2000X
The 2000X has 4M internally, they just cripple it in software.
Dave.
Offline elektrinis
« Reply #556 on: November 14, 2012, 12:03:48 pm »
OK, found some bugs...
1. Amplitude.
5V/div:
2V/div:
Closer look timewise:
I do know what clipping is. This zooming in was never a problem with Rigol.
2. Sensitivity in 10-50mV range.
50mV/div scale:
20mV/div scale:
10mV/div scale:
Notice the scaling of chan #2. It is scaled "in software". So Agilent is bulshitting us.
3. Also there is a problem with rare pulses (sorry, don't have a screenshot): The signal is recorded, scope shows like 30 narrow pulses. When timebase is widened, only 1-2 pulses remain, where at least 10 pulses should be visible. Will try to capture this.
« Last Edit: November 14, 2012, 12:23:42 pm by elektrinis »
Offline tom66
« Reply #557 on: November 14, 2012, 03:39:29 pm »
I wish someone figured out how to crack the 2000X. Now that would be interesting would it be considered piracy if you enabled features that were always there? Do you sign an EULA when you boot the scope for the first time?
Offline ferkapu
  • Country: hu
« Reply #558 on: November 14, 2012, 04:15:00 pm »
Please don't forget 3000x if we're talking about cracking!
Come on guys let somebody share the secret!
The hobbists will never pay for the expensive options, just dreams about it...
Offline benemorius
« Reply #559 on: November 14, 2012, 11:16:56 pm »
Someone who has the newer firmware installed would need to test how far in the past the date can be set. As long as you can still move the date back far enough, you can probably keep your trials. Don't get your hopes up though.
Offline DavidDLC
« Reply #560 on: November 14, 2012, 11:27:47 pm »
I was able to set it back only 3 days no more.
Offline benemorius
« Reply #561 on: November 14, 2012, 11:29:15 pm »
The datasheet says that the 1mV scale is a software expansion of the 2mV scale.
    • Mike's Electric Stuff
« Reply #562 on: November 14, 2012, 11:31:02 pm »
Pretty sure this is mentioned in the spec.
Day Job: Mostly LEDs
Online EEVblog
« Reply #563 on: November 14, 2012, 11:32:13 pm »
Crack it open and pull the 32KHz crystal maybe  ;D
Dave.
« Reply #564 on: November 14, 2012, 11:33:21 pm »
3 days from when - current, firmware release, trial install?
Wonder what happpens if you short the RTC crystal to freeze the clock?
Offline DavidDLC
« Reply #565 on: November 14, 2012, 11:34:58 pm »
3 days from the current date.
Offline pickle9000
« Reply #566 on: November 14, 2012, 11:54:38 pm »
Can the clock be set from the usb? WindowsCE devices can auto update the clock from the host computer. Are the features unlocked after a flash update?
Offline benemorius
« Reply #567 on: November 15, 2012, 12:52:58 am »
The original fix starting with version 2.0 (or maybe 2.12) was to prevent setting the date further in the past than the firmware compile date. It sounds like you're saying that has changed now? Do you mean that as the days progress you are unable to go back more than three days at a time on any given day?
Or is it the case that you have installed firmware 2.20, which was compiled on 2012-11-08 (approximately three days ago), and you're unable to set the date further back than that? This would be consistent with the original "fixed" behavior.
If the fix has indeed changed, then perhaps the date can be set in the past prior to upgrading the firmware. Has anyone determined whether it is allowed to downgrade the firmware from 2.20/2.12 down to 2.0? Has anyone noted whether a date has survived a firmware upgrade and remained further in the past than would otherwise be allowed?
I have tried setting the date via usb on 2.12 and the same restriction was imposed - setting the date prior to the firmware compile date was rejected.
Offline DavidDLC
« Reply #568 on: November 15, 2012, 02:44:46 am »
Correct, I did the test on the Nov 11th, so 3 days after the date of the update. ( Nov. 8th )
Today I did the test again and I'm able to set it back to Nov 8th. only
Offline benemorius
« Reply #569 on: November 15, 2012, 03:17:10 am »
So I suppose nothing seems to have changed on the trial license front and the outlook is rather bleak for those with models which are new enough to not be hackable anymore yet old enough to not have some of the newer firmware features.
It would still be interesting to know:
1) if the firmware can be downgraded back to a previous version
2) if the date setting (2012-06-01 for example) will survive a firmware upgrade (to version 2.20 for example, which would normally impose a date restriction of 2012-11-08 or later)
Offline NEDM64
  • Country: pt
« Reply #570 on: November 15, 2012, 04:01:41 am »
Hi, I got myself an entry model, love it, plus it comes with a decent signal generator, that's good as I am starting my home lab. The only complaint would be of the small memory, but that's kind of expected...
Also got the DVM, and I installed both licensees, but I don't see where you can turn it on... somebody?
Are you thinking about buying Keysight test equipment? Think about this
Offline benemorius
« Reply #571 on: November 15, 2012, 04:21:54 am »
Check the analyze menu.
Offline ferkapu
  • Country: hu
« Reply #572 on: November 15, 2012, 09:27:28 am »
Let pleeease somebody(who has fw2.00 or 2.12 or 2.20)  try to downgrade the firmware! I think many of us dare to upgrade to fw2 because we loose many functionalities if can't be restored the original v1.xx firmware with trial licenses!
Another interesting question: is it possible to ask for and get trial license for the same
machine two times? I mean if the last trial asked a year ago...
This is the real situation when somebody sell his machine to another company, and this company requests for trial to the same serial.
So maybe the agilent input fields needs to be manipulated to another company/name, and and brand new trials comes...
I'll try it but pleease somebody try to downgrade his 2.xx fw to 1.xx. %-B
Online EEVblog
« Reply #573 on: November 15, 2012, 09:39:00 am »
Just upgraded my firmware in the 3000X today and yes, it now has the AWG modulation capability like on the 4000X. Nice.
Now, how about burst capability Agilent?, pretty please?.  ;D
Dave.
Offline ferkapu
  • Country: hu
« Reply #574 on: November 15, 2012, 10:01:36 am »
Dave.
Sounds easy. Does the machine have external RTC chip or integrated into uC?
Does we have any hi-res pictures from the motherboard?
