Author Topic: New Agilent scopes  (Read 388398 times)
Offline DRT
Re: New Agilent scopes
« Reply #650 on: May 09, 2013, 08:07:35 pm »
Here you go. The maximum square wave frequency is 10MHz. Rise time is about 19ns, so it's not very square at this frequency. This was with 50 Ohm coax and the input set to 50 Ohms, however it looks the same without the termination.
Offline Hydrawerk
« Reply #651 on: May 09, 2013, 09:29:01 pm »
I can't find datasheet for DSOX3WAVEGEN that's why I ask someone to check square wave in scope.
Why not? It's a part of the DSOX3000 datasheet . http://cp.literature.agilent.com/litweb/pdf/5990-6619EN.pdf Look at page 23.
« Last Edit: May 09, 2013, 09:34:58 pm by Hydrawerk »
Offline Hydrawerk
« Reply #652 on: May 09, 2013, 09:39:38 pm »
HP 33120A has only 40Ms/sec. It's an obsolete product... I would not buy it. http://cp.literature.agilent.com/litweb/pdf/5968-0125EN.pdf
On the other hand, it has a bigger output level 20V peak peak, it's better than DSOX3000 at this.
Offline hooj
  • Country: ru
« Reply #653 on: May 10, 2013, 06:36:23 am »
Thanks!!! Can you make 100kHz square wave 2.8Vp-p screenshot? :)
HP 33120A was just for example. I think about Philips PM 5193  :P
http://www.ko4bb.com/Manuals/Philips/Philips_PM5193_Operation_Manual.pdf
Offline DRT
« Reply #654 on: May 10, 2013, 12:18:44 pm »
100kHz as requested, 2.5Vpk-pk since that's the most it will do into a 50 Ohm load.
Offline Tooms
« Reply #655 on: May 10, 2013, 06:48:54 pm »
Here is my Agilent 33522A with 100kHz square wave 2.8Vp-p at 50ohm and the Agilent MSOX3024A with input at 50ohm
/Tooms
Offline Tooms
« Reply #656 on: May 10, 2013, 07:07:28 pm »
Here is Agilent 33522A with 10MHz square wave 2.8Vp-p at 50ohm and the Agilent MSOX3024A with input at 50ohm
Here is Agilent 33522A with 20MHz square wave 2.8Vp-p at 50ohm and the Agilent MSOX3024A with input at 50ohm
Here is Agilent 33522A with 30MHz square wave 2.8Vp-p at 50ohm and the Agilent MSOX3024A with input at 50ohm
/Tooms
Offline hooj
  • Country: ru
« Reply #657 on: May 11, 2013, 08:56:55 am »
Looks fine, thanks :)
Wow, looks great, rise/fall time is impressive, but 33522A too expensive toy.
I believe DSOX3WAVEGEN will be enough for my purposes :)
Offline Tooms
Offline Electro Fan
« Reply #659 on: June 04, 2013, 12:33:58 am »
New firmware available:
2000
3000
The 2000 got some serious love:
• SW option DSOX2MEMUP has been added to allow all channels up to 1 Megabyte of MegaZoom acquisition memory.
• The standard memory has been upgraded to 100 Kilobytes of MegaZoom acquisition memory per channel.
• SW option DSOX2EMBD has been added to support hardware accelerated I2C and SPI serial triggering and analysis, including decode, lister, and search capabilities.
• SW option DSOX2AUTO has been added to support hardware accelerated CAN and LIN serial triggering and analysis, including decode, lister, and search capabilities.
• SW option DSOX2COMP has been added to support hardware accelerated RS232/UART serial triggering and analysis, including decode, lister, and search capabilities.
I was in your exact scenario, and I finally went with the two channel 2000. Don't do it. You think you only need two channels, but once you start really getting into your microcontroller projects, you'll start saying, "damn, I wish I had a couple more channels!". I sold that scope and now I have a four channel 3000. Two more channels and the extra memory depth is totally worth it for me. There have been times already that I wish I had even more memory depth than what the 3000 has. The serial decode options on the 3000 are also nice.
Hi ToBeFrank,
I saw a couple of your posts that I merged together in the quote above.
Given your experience with the Agilents, I have some questions for you.  Thx
In the EEV video on the 2024A at about 20:30 I thought Dave said there is no serial decode capability, but at about 30:30 Dave seems to show serial decoding.  (No doubt, I'm confused :))  And in your list of firmware updates for the 2000 it looks like some good serial updates were included - maybe they are only available if you have the DSOX2EMBD option?
Also, according Agilent's literature serial search isn't available - is that correct?  (It looks like some level of serial review is available but maybe not "search"?)
Moving onto your post about the 2000 vs. the 3000, any chance you can update us on what are the top several reasons you are glad you made the move from the 2000 to the 3000 ?  I'm especially interested in anything related to managing the digital signals (serial and parallel) and anything that has to do with simulataneously displaying and time correlating the analog and digital signals.  Also, any info on the relative search and navigate features on the 2000 and 3000 would be great to understand.
One last question, specifically on I2C and SPI in case you have been working with these - what is the feasiblity of using the DSOX2EMBD with just 4 analog channels (vs. using the 8 channel LA probe)?  If this is practical, theoretically a user could start with DSOX2024A and the DSOX2EMBD and then add the MSO (8 channel LA) later if it's needed.   (Related to this, have you found any difference between the DSOX2EMBD and the DSOX3EMBD?)
Thanks! EF
Offline Hydrawerk
« Reply #660 on: June 04, 2013, 03:03:24 pm »
Hi !
After a long research, I found a way to try the optional features on the 2000x/3000x for more than 30 days.  :) Possibly also on the 4000x.
Drop me a PM if you're interested.
Looks good, but has somebody tried this?
Offline Hypernova
  • Country: tw
« Reply #661 on: June 05, 2013, 12:53:24 am »
Hi !
HW or SW mod?
Offline Hydrawerk
« Reply #662 on: June 05, 2013, 01:06:17 am »
Send a message to djvinc. It's a firmware modification.
Offline con-f-use
  • Country: at
« Reply #663 on: June 12, 2013, 10:27:58 am »
Hi there, I just took the chance and bought a used MSO2024A with WaveGen, VGA and Segmented Mem option for USD 2000. It was barely used as the department closed just 5 month after they bought it. Did I get ripped off?
Also was there a firmware-upgrade to support arbitrary waveforms on the X2000 series? I recall Dave mentioning something in a video.
« Last Edit: October 25, 2013, 08:24:45 pm by con-f-use »
Offline Hydrawerk
« Reply #664 on: June 12, 2013, 05:49:23 pm »
No, it was for the X3000 series.
Offline kg4arn
« Reply #665 on: June 12, 2013, 06:31:48 pm »
Hi there, I just took the chance and bought a used MSO2022A with WaveGen, VGA and Segmented Mem option for USD 2000 from my university. It was barely used as the department closed just 5 month after they bought it. Did I get ripped off?
Also was there a firmware-upgrade to support arbitrary waveforms on the X2000 series? I recall Dave mentioning something in a video. Is it free?
Sounds like a good deal to me.  Looks like these are going for over 3K new with the VGA and the Seg Mem.
There's a buy one get one free upgrade promotional from Agilent right now.
http://www.home.agilent.com/agilent/editorial.jspx?cc=US&lc=eng&ckey=2309757&nid=-536902447.0.00&id=2309757
Offline plesa
« Reply #666 on: July 04, 2013, 09:01:38 pm »
Has anyone idea what is behind licences Infiniium mode and Remote Log in the current 2.35 firmware?
I'm not sure if both were present in any previous versions.
Offline con-f-use
  • Country: at
« Reply #667 on: July 09, 2013, 11:34:45 am »
Is there a way to have serial decoding on the logic channels (X2000)? I want to be able to read the ASCII message from an FTDI on one of the logic channels. It works with the analogue channels but you cannot enable serial decode when the logic analyzer is running. I don't really get why the scope doesn't do that. Once the aquisition ended the scope should have plenty of time to decode the 1s and 0s from the logic channels into something human readable.
Offline Blue
  • Fighting for peace is like fucking for virginity
« Reply #668 on: July 27, 2013, 11:46:26 am »
Anyone know what djvinc meant with firmware update?
I cannot find him any more on the members list.
Offline Bored@Work
« Reply #669 on: July 27, 2013, 12:29:37 pm »
If I remember it correctly he wanted to go / was asked to go. He was selling firmware hacks and moved on / was moved on when that didn't go down well here.
Offline dr.diesel
« Reply #670 on: July 27, 2013, 12:43:42 pm »
Can you get a scope screenshot from the Agilent web interface?
Offline lewis
  • Nullius in verba
« Reply #671 on: July 27, 2013, 01:14:38 pm »
yes!
I will not be pushed, filed, stamped, indexed, briefed, debriefed or numbered.
Offline dr.diesel
« Reply #672 on: July 27, 2013, 01:22:43 pm »
yes!
Mmmmmmm, that is a key feature I'd like to have.  Something Rigol doesn't offer, at least on the DSA they don't.
Offline EEVblog
« Reply #673 on: July 27, 2013, 01:28:42 pm »
He voluntarily asked me to remove his account and his posts, so I did so.
    • Mike's Electric Stuff
« Reply #674 on: July 27, 2013, 01:31:48 pm »
yes!
This is the thing I mostly uses LAN for on my MSO6000. What would be handy though is the ability to do a colour-invert to get a white background for when you want to print it - annoying to have to put it throug a graphics program to do this every time.
Day Job: Mostly LEDs
