Author Topic: EEVblog #1052 - BEWARE Crap Banana Plugs!  (Read 17163 times)
Offline trebejo
Re: EEVblog #1052 - BEWARE Crap Banana Plugs!
« Reply #25 on: May 13, 2022, 11:25:10 pm »
\$\Omega\$ \$\Omega\$ \$\Omega\$ the temptation to post this, necrology is not to my taste, but good suppliers from The Big Country are so good to find... nonetheless, my apologies to the necro-averse.
Good ones and good supplier  :-+
https://www.ebay.com.au/itm/12-pcs-Audio-Speaker-banana-plug-Audio-Jack-connector-24K-Gold-plated/112144340776?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
https://www.ebay.com.au/itm/10pcs-4mm-Gold-Connector-Banana-Plugs-Adapter-change-to-spade-Adapter/122385977092?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
https://www.ebay.com.au/itm/10set-5color-Gold-Plated-Brass-Stackable-4mm-Banana-Plug-Speaker-Cable-Connector-/253102319127?hash=item3aee12e617&_uhb=1
Thank you so much for this, you have saved me much doubt and hesitation.
Alas, ebay links are not permanent...is the supplier called panpa1688? I found it by searching for that "10set-5color" title and it was still intact. I would post the apparent current version (USA) of that ebay link, but then...
Ok, but like I said, not permanent: https://www.ebay.com/itm/284616540836 .
Online thm_w
  • Non-expert
« Reply #26 on: May 16, 2022, 08:50:30 pm »
I would be tempted to just go for this style instead, very strong springs: https://www.aliexpress.com/item/4001072043961.html
Even the genuine ones are not terribly expensive, but they may not be easily available outside of europe.
Although I do like the angled entry part.
These also look interesting https://www.aliexpress.com/item/32872176812.html
