Author Topic: Is This A Takeover Bid?  (Read 3943 times)
Offline German_EETopic starter
« on: September 24, 2018, 06:52:42 pm »
If you've been around as long as me then you'll remember the good old days of EEVBlog with Mailbag Monday, Teardown Tuesday and even the odd Fundamentals Friday. It appears that those days are behind us (although things can change), but I have made one interesting discovery.
Head off to You Tube channel https://www.youtube.com/user/TheDefpom/videos?disable_polymer=1
OK, the accent will take some getting used to but you'll find a mailbag Monday, a Teardown Tuesday and a Fix it Friday to start your weekend off. So far I've counted sixteen videos for September so there's lots to see.
We will know if this is a real takeover bid when Defpom starts to produce his own test equipment
Warren Buffett
The following users thanked this post: TheDefpom
Offline NivagSwerdna
Re: Is This A Takeover Bid?
« Reply #1 on: September 24, 2018, 07:31:23 pm »
He's using a knock-off copy of DaveCAD renamed DefCAD but otherwise seems OK as a channel... at 2 orders of magnitude subscribers less currently.
Good luck to him.
Offline wilfred
« Reply #2 on: September 24, 2018, 11:13:35 pm »
I'm OK with a homage to DaveCAD done by fans on their own channel. Lot's of people have been inspired by the EEVBlog to create a channel. It is a great time to set up a YT channel and share your hobby with others all over the world. There is so much choice and it is getting bigger each day.
I'm quite happy with new channels pitched at a more accessible level for me as a humble (if lazy) hobbyist. I'd like Dave to go back to include more hobbyist level content too.
But I think it's great there are more channels where ideas and information can get shared. It will help foster new interest in electronics as a hobby. When I was a kid there were a range of magazines that did that.
I hope Defpom doesn't burn out with this flurry of content.
Online NiHaoMike
    • Facebook Page
« Reply #3 on: September 25, 2018, 01:47:41 am »
Good luck to him.
DaveCAD is open source.
https://github.com/scanlime/davecad
Online EEVblog
« Reply #4 on: September 25, 2018, 02:30:13 am »
« Last Edit: September 25, 2018, 02:35:14 am by EEVblog »
Online Halcyon
  • Global Moderator
The following users thanked this post: NivagSwerdna
Offline Mr.B
« Reply #6 on: September 25, 2018, 02:58:52 am »
LOL
Offline ivaylo
« Reply #7 on: September 25, 2018, 05:55:47 am »
It’s a nice routine, glad someone is sticking to it. Subscribed.
Offline TheDefpom
  • YouTuber Nerd - I Fix Stuff
    • The Defpom's Channel
« Reply #8 on: September 26, 2018, 04:45:57 am »
Lol, I designed a simple high voltage leakage tester project, there is a video series playlist on my channel, open source so you can make it using my files if you like.
Certainly not a take over bid, my level of skills are nowhere near Dave’s, but I do enjoy fixing things, which is why I buy so much broken stuff, and capacitors.
« Last Edit: September 26, 2018, 04:53:10 am by TheDefpom »
Cheers Scott
The following users thanked this post: SeanB, ivaylo
Offline wilfred
« Reply #9 on: September 28, 2018, 10:40:19 am »
Well Fran's latest mailbag (10) has effectively conquered the calculator space.
Online rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #10 on: October 02, 2018, 08:44:48 pm »
The name DaveCAD may be the most famous, but it is far from being the first. In the 1990s we used to "sign" a bunch of different types of drawing <something/someone>CAD.
