Author Topic: EEVblog 1383 - Human Battery Energy Harvesting BUSTED  (Read 4239 times)
Offline EEVblogTopic starter
« on: March 26, 2021, 10:41:44 pm »
It's peltier thermo electric generator TEG time again!
This time the University of Colorado Boulder claim to have a new flexible TEG device you can stick on your skin that can power wearable and Internet of Things devices.
Can it? Dave runs the numbers...
The paper: https://advances.sciencemag.org/content/7/7/eabe0586
UoC video:
Anton's Pretrov's channel:
https://odysee.com/@whatdamath:8
https://www.youtube.com/channel/UCciQ8wFcVoIIMi-lfu8-cjQ
The following users thanked this post: ogden
Online rhodges
  • Available for embedded projects.
    • My public libraries, code samples, and projects for STM8.
Re: EEVblog 1383 - Human Battery Energy Harvesting BUSTED
« Reply #1 on: March 26, 2021, 11:50:03 pm »
How about making "energy harvesting shoes" that can collect thousands of volts when used on common carpet?
Currently developing STM8 and STM32. Past includes 6809, Z80, 8086, PIC, MIPS, PNX1302, and some 8748 and 6805. Check out my public code on github. https://github.com/unfrozen
The following users thanked this post: amyk
Online mawyatt
« Reply #2 on: March 27, 2021, 12:27:27 am »
Remember a methane powered fuel cell suppository  ;D
A new program is to be released next Thursday based on this technology is called Unlimited Power Yielding Oxygen User Restricted Source from the Federal Agency Research Technology Sector.  :-DD
Best,
« Last Edit: March 27, 2021, 06:07:37 pm by mawyatt »
~Wyatt Labs by Mike~
Offline David Chamberlain
« Reply #3 on: March 27, 2021, 04:29:17 am »
Free Energy
Offline Cnoob
« Reply #4 on: March 27, 2021, 07:42:34 am »
Seiko are one of the world leaders in harvesting energy from humans.
They have two types one is called an automatic and the other is called a kinetic. ;D
Offline Domagoj T
  • Country: hr
« Reply #5 on: March 27, 2021, 07:45:57 am »
Dave, you're mentioning the possibilities of niche application such as remote sensing but I'm having trouble thinking of a realistic scenario where this would be sensible. For this to work, there needs to be a temperature differential, but unless there is a powered device that generates enough heat to produce significant temp dif involved, the temperatures in nature tend to equalize. Of course, if you have a powered device that generates tens of degrees of temperature differential, you might want to consider tapping into that power source. I'm sure that at these power levels, no one would even notice.
If you can't use a battery for whatever environmental of regulatory reason, wouldn't a solar cell such as the one in the calculator still be a more suitable solution? Charge a tiny supercapacitor for those cold nights or cloudy days.
Speaking of solar cells, energy harvesting and wearables, I have a Seiko solar powered wrist watch. The entire face is a solar panel and just by wearing it daily, exposing it to mostly indoor light, it provides enough energy to keep the watch running from early spring to late autumn (I need to remember to expose it to direct sunlight for a few hours in autumn to charge up the battery for winter). I'm fairly sure you've covered this in one of your previous videos, explaining that a simple and cheap battery is still more sensible approach and I agree, the watch is a bit gimicky, but it actually works. The watch itself has a microcontroller that regulates movement, so when the battery is depleted, it first starts moving the second hand two positions, that waiting for two seconds. If you still don't recharge the battery it parks the second hand a 3 o clock, but it still counts the time for a while so once you recharge the battery it moves the hands to show correct time. So it's a fairly complex electromechanical device. The solar panel is about 27 mm in diameter, so about 5,7 cm^2.
Offline Pack34
« Reply #6 on: April 13, 2021, 02:45:45 pm »
The human battery plot in The Matrix wasn't the original reason. The Wachowski's originally wrote it as everyone was being connected to create a massive computer. The processing power of the human brain was supposed to be vastly greater than what the machines could do themselves. It was suggested that people wouldn't understand that, so they changed it "people being batteries".
