Right, first try the latest GCC version, maybe the bug is already fixed.
If not, good luck finding the bug in GCC. If you have lots of time, you can compile GCC with debug information and then debug the compiler and linker. If you don't have time, compile it with Keil µVision, they use a different compiler, written by ARM. It is even free, if you need less than 32 kB.
If you want to stick with GCC, and the latest version has still the bug, just comment out everything step by step until the linker error doesn't happen anymore. Or rollback to older versions of your code that works (I assume it is all version controlled and you commit often) and apply the changes to the current version step by step. You can then see exactly what causes the problem and probably find a workaround for it, like different link order etc., or the GCC guys can help then.
PS: GCC code quality sucks. By fuzzing the compiler, someone found
found 100 bugs. The same fuzzing found 8 bugs in the Rust compiler and 9 bugs in LLVM/clang. Maybe it is possible to use LLVM/clang as the compiler and linker. But might need some work for writing new linker files, Makefiles etc.
