Author Topic: EEVblog1543 - Mailbag FNIRSI HS-01 USB Portable Soldering Iron  (Read 16939 times)
Online EEVblogTopic starter
A look at the $30 Fnirsi HS-01 USB PD Portable soldering iron.
It is better than the E-Design Miniware TS-80P?
https://s.click.aliexpress.com/e/_DFykRxj
Offline Helio_Centra
Re: EEVblog1543 - Mailbag FNIRSI HS-01 USB Portable Soldering Iron
« Reply #1 on: May 11, 2023, 12:42:20 am »
The American company Pine 64 makes a clone of the TS100 or TS101 called the Pinecil. and it is $26
https://pine64.com/product-category/pinecil/
Up to 88W, 12-24V, takes DC jack or USB-C PD, comes with the hacked firmware already installed.
« Reply #2 on: May 11, 2023, 01:34:54 am »
So the rabid fanboys in the video comments section have told me  ::)
Looks like they have taken over from the TS100 fanboys.
« Reply #3 on: May 11, 2023, 03:22:52 am »
They made a better TS100 for a third of the price. That's how they converted me.
Offline kmike
« Reply #4 on: May 11, 2023, 06:05:30 am »
I am not a fanboy of either soldering irons, I just needed a new iron for field work.
The pinecil costs 52€ in europe plus shipping without a cable or a power supply and with only 1 tip. Also I don't like the idea of fiddling with an m2 screw (and allen wrench) in the field, when I have to replace the tip.
I bought the HS-01 from aliexpress for 73€ with a cable, power supply and 6 tips. Lets see how long it lasts...
Thanks Dave for the video! :-)
The following users thanked this post: Jacon
Offline .RC.
« Reply #5 on: May 11, 2023, 06:24:31 am »
There seems to be quite a few manufacturers of these small portable irons now. One downside I see is they all seem to make use of their own tip design which limits options.
With the advent of the T12 clones, cordless power tool batteries and 3D printers, you can whip together something I think better as you get a better selection of handles and tips and it is similar priced or maybe even cheaper.   Also looking at the Fnirsi one, to me it looks ungainly to be handling such a large cylindrical shaped thing like that.  Maybe others are more used to it, but I am more used to a smaller more finesse sized handle that I feel I can wield with greater precision.
Here is one I prepared earlier. I know it is not quite as handy as the pocket ones though.
« Last Edit: May 11, 2023, 06:36:19 am by .RC. »
The following users thanked this post: AmnevaR
Offline free_electron
    • SiliconValleyGarage
« Reply #6 on: May 17, 2023, 04:43:54 pm »
"OS: Ralim’s IronOS build
Chipset: Bouffalo BL-706
CPU: 32-bit RV32IMAFC RISC-V “SiFive E24 Core” @ 144 MHz"
Nope. No way. Do not want. Soldering irons don't need an os. They need a couple of opamps and a 7106 or 7107 if you must have a display for temperature and setpoint. (ok you can use a cheap micro to perform a/d and show on a display and maybe a dac to control the temp setpoint.
The following users thanked this post: Warhawk
Offline thm_w
  • Non-expert
« Reply #7 on: May 17, 2023, 07:44:47 pm »
Battery based is better in some situations, so yours is a nice option.
If you search around on ali and you'll find irons using standard tips: T12, C245, C210
Agree with the odd shape. This KSGER one looks a bit more ergonomic, and is $28: https://www.aliexpress.com/item/1005005519807256.html But its direct 12V instead of TypeC. Unsure if it would handle higher voltages of a 18V battery.
Some of the C245 stuff is type C: https://www.aliexpress.com/item/1005004883610424.html
Or a wired 245 + good stand: https://www.aliexpress.com/item/1005005366090783.html
Offline Jesse_G_EE
« Reply #8 on: May 18, 2023, 03:55:11 pm »
I was actually curious about what that USB Power Monitor Device is?
Offline thm_w
  • Non-expert
« Reply #9 on: May 18, 2023, 08:55:13 pm »
Search for fnirsi power meter, there are a few different models.
https://www.aliexpress.us/item/3256802754714015.html
Offline Jesse_G_EE
« Reply #10 on: May 18, 2023, 09:10:57 pm »
Thanks friendo!
Offline Doctorandus_P
« Reply #11 on: May 19, 2023, 03:39:00 pm »
So it's not compatible with the T12 tips.
It can't normally show a temperature on it's display.
It can't make a decent connection to the tip.
It seems that fnirsi iron is just as horrible as their scopes.
I'm quite like "cheap" tools, but there is a minimum quality standard for tools to be "acceptable", and the fnirsi garbage just does not meet it. A "decent product" should have a combination of "something useful", and the "absence of show stoppers and stupidity", and fnirsi seems to always fail on that second part.
I did not see the whole video, I stopped after I saw the trouble with recognizing the tip.
I wonder why people even bother reviewing that stuff.
« Last Edit: May 19, 2023, 03:45:45 pm by Doctorandus_P »
The following users thanked this post: MathWizard
Offline thm_w
  • Non-expert
« Reply #12 on: May 19, 2023, 10:05:39 pm »
And as usual you don't bother reading a few minutes to find the actual info:
- The tip was loose because Dave didn't screw on the collar holding it in place
- The temperatures bounce around on T12 clone type tips until the thermocouple burns in, this should resolve after 5-10mins or so. Presumably Hakko tips are pre burnt-in, Pace has stated they do this to theirs.
The following users thanked this post: dinoboy, Jacon, MathWizard
Offline dinoboy
  • EE101
    • DC
« Reply #13 on: November 06, 2023, 11:43:07 pm »
Anybody knows if the "KAIWEETS Mini Lötkolben Set digital aus Aluminium, Typ-C-Kabel, Adapter, 5 Ersatzlötspitzen, Temperatur Einstellbar 80-420°C, Soldering Kit KETS02" is the same hardware and firmware as the Fnirsi?
https://kaiweets.com/en-de/collections/soldering
The tool is all over youtube and amazon, with high availability at intl amzn warehouses. Maybe in the long term the HS-01 will become the most popular USB soldering iron simply because of the marketing power of Kaiweets which is not a small company/name in the business.
Offline MathWizard
« Reply #14 on: December 19, 2023, 01:15:00 am »
Well what are some good cordless/chargeable mini-soldering irons? I would like a mini one for just for when I have some DUT, all wired up on the scope, and I don't want to unhook it all and go over to the solder iron to change 1 little part. And I don't want my big soldering station next to my touchscreen scope.
Any good ones in the $70-100 range ? I've seen the TSxxx ones, I don't remember them being cordless, I thought they just had new style heaters/tips. I'll have to check them out too.
Offline thm_w
  • Non-expert
« Reply #15 on: December 19, 2023, 01:20:44 am »
See what I suggested above.. ksger
Offline MathWizard
« Reply #16 on: December 19, 2023, 01:40:21 am »
I'll see if it's on amazon, aliexpress never worked with my bank in the past.
Just checking out the pencil, and it's amazing reading it's MCU spec's, 32-bit, 144MHz. That's probably faster than the best computers in my highschool at the time.
https://pine64.com/product/pinecil-smart-mini-portable-soldering-iron/
Offline Veteran68
« Reply #17 on: December 19, 2023, 04:55:12 am »
I have both the FNIRSI HS-01 and Kaiweets KETS02, they are identical hardware. I haven't done a side-by-side comparison or looked that closely but I don't recall any UX differences in the firmware so my guess is they're the same.
Offline thm_w
  • Non-expert
« Reply #18 on: December 19, 2023, 09:58:32 pm »
I wouldn't bother with amazon. I'm sure we've discussed this before, but you can either use paypal to pay on aliexpress, or sign up for Koho/Wealthsimple/etc. within a matter of days.
Offline solidhit
  • Country: gr
« Reply #19 on: December 29, 2023, 08:59:34 am »
Hello, the  Kaiweets KETS02 has a firmware update available whereas the HS-01 does not. Could we apply that update to the HS-01 if the hardware is really identical?
Offline Veteran68
« Reply #20 on: December 29, 2023, 10:29:16 pm »
I should clarify -- when I say the hardware is identical, I mean in appearance and UX. I have not torn down either to compare internals. I would probably not risk upgrading the firmware from one to the other until I've heard someone else do it successfully, and who knows if the firmware tool will even allow you to.
That said, FNIRSI has an almost identically named firmware update that would imply they might be the same:
FNIRSI filename: HS01_V0.1.s19
KAIWEETS filename: KETS02 temperature calibration_V0.1.s19
However they are very different, with different file sizes as you can see in the comparison screenshot below. The FNIRSI version also dates from a year ago.
Offline solidhit
  • Country: gr
« Reply #21 on: January 06, 2024, 10:17:07 am »
Hello, fnirsi just uploaded v0.3 of their firmware for the HS-01 soldering iron. They only published the firmware file, no "what's new" and no tool to update the firmware. So I used the tool for the kaiweets KETS02 which sure enough recognized the fnirsi HS-01 as a kaiweets KETS02, allowed me to choose the fnirsi firmware file and programmed the iron as expected. Of course the tool doesn't say anything about firmware versions (the one already installed and the one to be programmed) nor does the iron itself has an option to display the firmware version. Well, maybe I don't know what's new but at least I got the latest firmware installed and the iron works fine!
« Last Edit: January 06, 2024, 10:37:19 am by solidhit »
Offline cleopete
« Reply #22 on: February 01, 2024, 01:11:02 am »
Looks like Fnrisi has added the tool since your post, it's about meg smaller than the KETS02 tool.
