Author Topic: EEVblog #1229 - Mailbag  (Read 2540 times)
Offline EEVblogTopic starter
« on: July 16, 2019, 11:08:20 pm »
Mailbag with special guest Sagan!
SPOILERS:
TomTom XL GPS teardown
9:26 Casio RM-9850 graphing Calculator
18:15 40th Anniversary of the 6809 and a special demo board
https://gitlab.com/dfffffff/gcc6809
6809 gcc compiler
23:14 Japanese Anime and various prototype boards
https://gerbolyze.jaseg.net
32:34 WebFPGA Beginner web based FPGA development system Kickstarter: https://www.kickstarter.com/projects/ryanmjacobs/webfpga-rapid-fpga-development-system
Raspberry Pi Zero aluminium case
121GW Multimeter holder
Offline johnlsenchak
  • js@antihotmail.com
    • paypal.me/johnsenchak
Re: EEVblog #1229 - Mailbag
« Reply #1 on: July 17, 2019, 04:22:47 am »
That  multi-meter  stand would  have  looked  a  lot better if it was in light  blue  , the  same   color   as the  GW  meter  Also that would be real  nice
as a  accessory  item   if you sold  it along  side with the   multi-meter .
« Last Edit: July 17, 2019, 04:24:51 am by johnlsenchak »
John Senchak "Daytona  Beach  Florida "
 jls (at)  antihotmail.com   http://www.antihotmail.com
https://www.facebook.com/john.senchak.1
« Reply #2 on: July 17, 2019, 04:51:01 am »
Pantone 3005C  ;D
Offline mrpackethead
  • D Size Cell
« Reply #3 on: July 17, 2019, 11:20:20 am »
Go to the video turn on closed captions and read what Sagan apparently says I’m the first 30 seconds or so
The following users thanked this post: Towger
Offline tchicago
« Reply #4 on: July 18, 2019, 08:27:02 pm »
Looks like that calculator was a rush attempt to hack something new from the existing design. Got the existing board designs from the previous model, slapped a clumsy cable to connect a display from a different vendor. Attached the IR interface and battery on the separate boards form factor adapter boards. Ready to ship.
After all, the customers aren't expected to see all that mess inside.
Offline meeko
« Reply #5 on: August 16, 2019, 03:53:32 pm »
Yes, the figurine is of an anime character, Sugiura Ayano from Yuru Yuri.
Offline German_EE
« Reply #6 on: August 17, 2019, 04:56:21 pm »
That's just the software not coping with an Australian accent. It struggles on 'The Signal Path' as well because Sharier talks too fast.
Warren Buffett
