Cheaper then decode options on some scopes
Quote from: Marinated on April 04, 2017, 05:13:14 amQuote from: tautech on April 04, 2017, 03:02:27 amNotice Siglent roll their own PSU, not some off the shelf item that they can't maintain the spec and QC of.I don't want to derail but that is a slightly surprising and suspiciously silly slippery slope argument. It's not like they depend on the performance of any other third party components in this design amirite?Only offered as an observation.Over the years there have been a # of threads here with failures of scope PSU's, in many cases they have not been made by the scope manufacturer. Could you call this modus operandi a weak link ? I do.
When will the scope actually be available?
- Why do we have two optocouplers ? Isn't one enough ?
Quote from: tigrou on April 04, 2017, 07:21:53 pm- Why do we have two optocouplers ? Isn't one enough ?A little tip. See the directions of information transfer.
Quote from: rf-loop on April 05, 2017, 07:56:21 amQuote from: tigrou on April 04, 2017, 07:21:53 pm- Why do we have two optocouplers ? Isn't one enough ?A little tip. See the directions of information transfer. I doubt it - ....The second optoisolator is probably carrying the 'line trigger' signal from primary side to secondary side.
Quote from: nfmax on April 05, 2017, 08:05:08 amQuote from: rf-loop on April 05, 2017, 07:56:21 amQuote from: tigrou on April 04, 2017, 07:21:53 pm- Why do we have two optocouplers ? Isn't one enough ?A little tip. See the directions of information transfer. I doubt it - ....The second optoisolator is probably carrying the 'line trigger' signal from primary side to secondary side.This is not information transfer??
cat /proc/cpuinfocat /proc/meminfo
find /
You had a full blown shell on the prompt there, ash is the shell. Try run some of the following to get some interesting information out:Code: [Select]cat /proc/cpuinfocat /proc/meminfo
And you can list all the files, provided it has the tool installedCode: [Select]find /
Quote from: gnif on April 05, 2017, 12:55:05 pmYou had a full blown shell on the prompt there, ash is the shell. Try run some of the following to get some interesting information out:Code: [Select]cat /proc/cpuinfocat /proc/meminfoFrom the video: Quote from: gnif on April 05, 2017, 12:55:05 pmAnd you can list all the files, provided it has the tool installedCode: [Select]find /It also has the OS, kernel version, etc.
cp -R /etc /whatever-path-the USB-drive-is-mounted-to
Nice review. I find the multi-layer board completely mind boggling. Is that routed by human, computer or magic? It's also completely awesome that those many layer boards are becoming such commodities.
Quote from: NivagSwerdna on April 04, 2017, 03:01:32 pmNice review. I find the multi-layer board completely mind boggling. Is that routed by human, computer or magic? It's also completely awesome that those many layer boards are becoming such commodities.They're not that hard to make...
Rigol Should build a 4 channel one using similar hardware to this, why they did not do it 4 channel, they have the ADC and the ZYNQ, they just needed to add the front end
