Using Keysight LXI (LAN eXtensions for Instrumentation) interface using Keysight BenchVue:
Keysight BenchVue is a software that provides virtual instrument panels for accessing and controlling network devices supporting LXI interface over Ethernet. With the LAN interface added to the scope, BenchVue worked just fine (a trial version of BenchVue can be downloaded from Keysight web site). The following screenshot shows a session with the modified EDUX1002A scope on which the Wavegen was unlocked too:
![](https://www.eevblog.com/forum/blog/eevblog-978-keysight-1000x-hacking/?action=dlattach;attach=1283893;image)
Custom software can be created in a number of usual ways in C, VB, VBA and other programming languages using Keysight I/O libraries.
Talking to LXI interface using telnet (port 5024):
With the LAN interface added it is possible to exchange SCPI commands and data with the scope just over Telnet using port 5024. Telnet credentials to log in to the scope are the same as for the regular Telnet connection provided earlier above. The following screenshot captured a few commands/responses exchanged that way:
![](https://www.eevblog.com/forum/blog/eevblog-978-keysight-1000x-hacking/?action=dlattach;attach=1283899;image)
Using WEB interface and FTP:
WEB server and \Secure\Infiniivision\web folder is the home folder of the scope’s WEB server, the one you get connected to from outside using your favorite Internet browser to the scope’s IP address. On the 1000X the web folder is empty but you can put WEB pages and applications in it and use it just like a regular WEB server, within the limitations of web technologies supported by Windows CE 6.0. Regular WEB sites, ASP and JAVA pages seem to work fine, as long as the WEB pages do not attempt to interact with the operating system by calling or creating COM objects that may not exist or unsupported.
FTP root folder:
FTP connectivity using the same credentials as for Telnet. In the scope file system the FTP root folder is set to \Temp. Once connected, two other folders can be seen:
![](https://www.eevblog.com/forum/blog/eevblog-978-keysight-1000x-hacking/?action=dlattach;attach=1283905;image)
Using FTP, files and data can be copied to the scope and back, which can be used in conjunction with Telnet to explore and experiment with the device. The FTP storage is however volatile, data is lost after a reboot.
Webdata folder is mapped to \temp\webdata.
Webupdate folder is mapped to \Agilent Flash\webupdate , which is a hidden folder and may somehow be used for firmware updates over FTP, not sure. It is not accessible from the browser using HTTP.
