Hi guys,
Here is my history of trying to modify the EDUX1002A into DSOX1002A.
I bought all the components (a few imported and others directly from here, Brazil). When unmounting the parts one of the white plastic connectors in the logic board became loose in the board and I've tried to put it back with hot air... result: it melted.
A long time after trying to realize the type of connector and brand, finally found it. Luckily got it as a sample and soldered it. (
https://www.te.com/usa-en/product-5177984-1.html)
All the other components were put in place as specified. Particularly the WSON LMH6552SD is hard to tell if its in place correctly... because the contacts are bellow the IC. That may be one of the issues I am facing.
When i finally put that to work... the oscilloscope turned on, but any signal I put in the channels 1 or 2 doesnt show anything. Neither the test function is working... it is acting like there was no probe. May be the trigger.. may be the WSON IC... how to know?!
Another thing is the product ID. Even replacing the resistor it still shows EDUX in the screen. Is there anything I am missing? My firmware version is FERCSA's 1.10.
Happy to hear some tips on how to solve it.
update: updated the firmware to 1.20 and still working the same.
