Author Topic: EEVblog #978 - Keysight 1000X Hacking  (Read 488451 times)
Offline Bud
Re: EEVblog #978 - Keysight 1000X Hacking
« Reply #750 on: December 25, 2020, 03:52:56 pm »
Why do you want that, there are 1.10 and 1.20 available now.  :-//
Several people have told you LNK method  used for 2000X-4000X scopes is NOT working for 1000X. Connect a serial console to the scope and you will see error messages if you try using a Lnk file.
The following users thanked this post: wp_wp
Offline wp_wp
  • Country: cn
« Reply #751 on: December 26, 2020, 12:09:51 am »
Thank you.
When I go into 1000X WinCE and 2000X WinCE,I find they have similar file structure.
So I am thinking why we can not add 1000X options like 2000X-4000X with link file.
Is there other segment in infiniivisioncore.dll or some file needing to change?
Offline Bud
« Reply #752 on: December 26, 2020, 01:45:35 am »
They may be similar but it does not work on 1000X. This is what you get if you try making a LNK file
LaunchInfiniiVision: -l MSO -l BW20 -l DIS
SHIM DLL, LoadRealDll [PalSStorage.dll] for [AgilentPalSStorage.dll]
SHIM [AgilentPalSStorage.dll] Get Process Addresses
Exception 'Raised Exception' (-1): Thread-Id=0457000a(pth=83df24f8), Proc-Id=045
6000a(pprc=83da9bd0) 'infiniivisionlauncher.exe', VM-active=0456000a(pprc=83da9b
PC=40068ae0(coredll.dll+0x00058ae0) RA=803782c8(kernel.dll+0x000062c8) SP=0002f2
d8, BVA=0002f3e4
PARSE ERROR: Argument: -l
             Couldn't find match for argument
Brief USAGE:
   infiniivision  [--ExtTalClk] [--IntTalClk] [--4GSa] [--5GSa] [--]
                  [--version] [-h]
For complete USAGE and HELP type:
   infiniivision --help
There is no -l argument option available in 1000X.
Good luck if you still want it.
Offline wp_wp
  • Country: cn
« Reply #753 on: December 26, 2020, 04:03:02 am »
d8, BVA=0002f3e4
Brief USAGE:
                  [--version] [-h]
Thank you.
I learn more.
Offline Bud
« Reply #754 on: December 26, 2020, 07:38:51 am »
Can someone please share their EDUX / 1000X Factory Cal files ?  They are in  the hidden \Secure\Cal  folder. File names are or similar to :
ServiceCal.dat
FactoryCal.dat
« Last Edit: December 27, 2020, 04:20:27 am by Bud »
Offline Bud
« Reply #755 on: December 27, 2020, 04:38:48 am »
Can someone help me with the Factory Cal files please  ?  :-/O
Offline Mwyann
« Reply #756 on: December 27, 2020, 09:42:30 am »
ServiceCal.dat
FactoryCal.dat
There you go, they come from a DSOX1102G though, hope it'll help you.
The following users thanked this post: Bud
Offline JDubU
« Reply #757 on: December 27, 2020, 04:30:19 pm »
Well, I've tested the 1khz signal from another scope and it looks the same.
My bet is that somewhere on the front end there is a weird thing. Maybe the output filter (after diff amp)
Can someone confirm that on DSO1102 the filter has 47uH and 4.7pF?
Did you mean 47nH instead of 47uH?
https://www.eevblog.com/forum/blog/eevblog-978-keysight-1000x-hacking/msg1983362/#msg1983362
Offline Bud
« Reply #758 on: December 27, 2020, 11:44:30 pm »
Good catch, should be 47nH.
Offline Bud
« Reply #759 on: December 27, 2020, 11:46:17 pm »
Thanks a bunch, it did help, more good stuff will follow shortly.
The following users thanked this post: Mwyann
Offline liviux
« Reply #760 on: December 29, 2020, 11:02:52 am »
No, my typo :P I used this one: LQP18MN47NG02D 47nH
Offline JDubU
« Reply #761 on: December 29, 2020, 04:56:48 pm »
2.2 Ohm series resistance is a bit on the high side for a 47nH 0603, but don't know how relevant that is in this particular circuit.
Offline Bud
« Reply #762 on: January 02, 2021, 07:54:22 pm »
Another problem I found last time is a jitter on external trigger. Scope can't align trigger edge with time 0.
Can you provide details of a test setup so I can try to replicate ?
Offline Bud
« Reply #763 on: January 04, 2021, 03:17:24 am »
Here is my contribution. The list of components to replace in the front end (both channels), trigger, product code, and three more resistors (display, edge adj and ext view) .
I also attached a few images from our colleagues in a different organization.
Moreover I'll update the list with the signal generator.
Two errors spotted in the Excel spreadsheet components list and the PNG screenshot (refer to the quoted post for details). An updated screenshot is attached.
The following users thanked this post: rbaleiro
Offline JDubU
« Reply #764 on: January 04, 2021, 03:26:12 pm »
Does a list exist for the 1000a --> 1000g wavegen components?
Offline Cesarsound
  • Country: br
« Reply #765 on: January 10, 2021, 01:21:15 pm »
Try this link to a full package (~30Mb) with a backup of the original 1.20 in Image2:
https://we.tl/t-3ODV5OcpUI
(the link will expire in 7 days)
I successfully applied the 1.20 Hack made by Bud to my DSOX-1102G which had firmware 1.10 previously, it works like a charm! Great job Bud, congrats! Julio. :clap:
« Last Edit: January 14, 2021, 04:39:58 pm by Cesarsound »
Offline cgrd
    • Chris Douglas
« Reply #766 on: January 13, 2021, 02:56:55 pm »
Hello! Thank you for the work you put into this. Would it be possible to get a re-share of the download? TIA!
Offline Mwyann
« Reply #767 on: January 13, 2021, 07:01:48 pm »
Give this a go: https://mega.nz/file/vcF0zZ5Z#6B3GNsS3t1eJuQx6uP3YR7wk3dpoAewSRzmdZuL2szY
The following users thanked this post: cgrd, effeffe
Offline cgrd
    • Chris Douglas
« Reply #768 on: January 14, 2021, 04:13:13 am »
Give this a go
Super, worked perfectly on my scope. Thank you kindly.
Offline candrian
« Reply #769 on: January 26, 2021, 12:47:33 pm »
Hi all,
I just received my new DSOX1202G and i noticed the FAN is noisy. It makes a noise like "grrrr" not that loud but if you sit at the bench for hours it's getting really annoying.
It looks really interested that you managed to hack DSOX1102. Is there a hack available for the newer model DSOX1202? I see all the replies are mostly for DSOX1102
Offline TK
« Reply #770 on: January 26, 2021, 02:11:41 pm »
Hi all,
The DSOX1202G has temperature controlled fan and noise should go low after a few seconds after turning the scope on.
This scope is linux based and there is no software hack available
Offline candrian
« Reply #771 on: January 26, 2021, 02:16:28 pm »
Hi all,
Thank  you for your fast response. Well it doesn't seem to go low after a few seconds, i have kept it on for 1-2 hours because i was working with and the noise was stable all the time. At least to my ears. The annoying thing is the noise type, it's not the air flow that you hear but something like grrrrr in higher frequency.
So for the linux version needs some further investigation.
Offline JDubU
« Reply #772 on: January 26, 2021, 03:52:11 pm »
In my experience, the high frequency "grrrrr" is caused by the turbulent airflow between the slot pattern in the case and the input side of the fan.  I modified my 1st gen 1000x by cutting out the slots in the case and replacing that function with a wire fan guard that is spaced farther away from the fan.  It almost completely eliminated the annoying high frequency noise and is now mostly just the lower frequency "shhhh" of air movement.
Here's a photo:
Offline candrian
« Reply #773 on: January 26, 2021, 08:39:24 pm »
This is a good idea. I gave a try with a quick 3D printed grid having in mind to reduce the possible FAN turbulence.
It made a small difference but there is still some noise.
(There is a cut in half to the printed part as it was a quick design and there was a mistake in the distances but it was still a good fit for test)
Offline JDubU
« Reply #774 on: January 26, 2021, 09:13:12 pm »
I wouldn't think that an added grill would help much.
I think that the annoying, higher frequency noise is being generated by the turbulence between each moving fan blade and the slotted grill in the case.  The sound would have already been created before the added grill comes into play.
As an experiment, try removing the back case of the scope to hear the difference (it's only four screws).
