Here is the boot log of the liberated 1.20
U-Boot 2010.03 (Oct 18 2011 - 14:28:06)Agilent P500
CPU: SPEAr600
DRAM: 128 MiB
Flash: 512 KiB
NAND: internal ecc 128 MiB
Debug serial initialized ........OK
RTC: 2024-20-12 1:103:51.26 UTC
Microsoft Windows CE Bootloader Common Library Version 1.4 Built May 7 2015 01:
38:03
Microsoft Windows CE 6.0 Ethernet Bootloader for the Agilent P500 board
Adaptation performed by Agilent Technologies (c) 2008
System ready!
Preparing for download...
Loading image 1 from memory at 0xD0600000
O
BL_IMAGE_TYPE_BIN
X
XXXXOOOOXXOOOOOOOOXOXOOOOOOOOXOOOXOOOOXXXOOOOOOOOOXOOOOXOXXOXOXXOXOXOXOXXXXOOXXX
OOOOOOXXOXXOXXXXXXOOOXXXOOXXOXOXXOXXOOOXOOOXXOOXOXOOOOXOXOOOOOXOOOXOOXOXXOXOXXXX
XXOXXXXOOOXOOOXOXOOOOXOOOOXOXOX
OOOOOOXOOOXOOXOOOOXOOOOXOOXXOOXOOOOOOOOOXOOOOXOOOOOOXOXOOOOXOXOOOOOOOXXOOXOOXOXO
OOXOOOXOOXXOXOXOOOXOXXXXXOXOXXXOXXXOXOXXOOOXXXOXXXXXXXXOXXXXXXXOXXXXOXOXXOXOOOXX
XXXOXXXXOOOXOXXOOX
XXOXXOOXOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
OOOOOOOOOOOOOOXXOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOXXXXOXOOOX
OXOOOXOOXXXXXXXXXXXXXrom_offset=0x0.
XXImageStart = 0x80361000, ImageLength = 0x1A857C0, LaunchAddr = 0x80362000
Completed file(s):
[0]: Address=0x80361000 Length=0x1A857C0 Name="" Target=RAM
Loading image 1 succeeded.
ROMHDR at Address 80361044h
Preparing launch...
RTC: 2024-20-12 1:103:51.29 UTC
Launching windows CE image by jumping at address 0x 362000
Windows CE Kernel for ARM (Thumb Enabled) Built on Mar 8 2013 at 17:05:33
Setting up for a Cold Reboot
Done Setting up for a Cold Reboot
Windows CE Firmware Init
BSP 1.0.0 for the SPEARHEAD600AB board (built Jun 10 2019)
Adaptation performed by ADENEO (c) 2005
+OALIntrInit
-OALIntrInit(rc = 1)
Initialize driver globals Zeros area...
pDrvGlobalArea 0xa0060000 size 0x800 (0xa0060800 -0xa0060000)
Initialize driver globals Zeros area...done
OALKitlStart
Firmware Init Done.
OALIoctlHalEnterI2cCriticalSection init i2c cs
++SER_Init: context Drivers\Active\14
SER_Init, dwIndex:2
SER2 got sysintr:0x00000017
SER2 Serial Port, new baud rate:0x1c200 (UARTCLK:48000000 IBRD:0x1a FBRD:0x2)
OHCI\system.c, GCFG_USBH1_SW_RST
OHCI\system.c, GCFG_USBH2_SW_RST
LAN PHY detected.
-EDeviceLoadEeprom 00:30:D3:20:D7:70
Phy found addr 15 (ticks=3502)
WaitForLink Start (ticks=3504)
Link Detected (ticks=3506)
GMAC Init : 100 Mbit/s FULL DUPLEX (MII)
Flushed Transmit Buffer
phyCfg->dwSpeed 0x64
phyCfg->bFullDuplex 0x1
<--EDeviceInitialize
GMAC DMA status register = 0x600004
GMAC Device enable interrupt
DriverStart
LIN: Data Valid
BALDWIN_DDI: cBaldwinHwIf::Init: Initializing...
BALDWIN_DDI: cBaldwinHwIf::Init: Scope successfully identified.
BALDWIN_DDI: cBaldwinHwIf::Init: Success!
Autonegociation Start (ticks=5533)
Autonegociation End (ticks=8038)
WaitForLink Start (ticks=8039)
Link Detected (ticks=8042)
cable attached
Device load time:
NANDFLASH: 0 ms
SNANDFLASH: 0 ms
USB Hard Disk Drive: 0 ms
Summary of scan:
All FATs on volume agree
Percent Fragmentation: 0
Invalid Directories: 0
Invalid Files: 0
Invalid Clusters: 0
Lost Cluster Chains: 0
ScanVolume \Agilent Flash (NANDFLASH) 0.306000
Summary of scan:
Invalid Files: 0
Invalid Clusters: 0
ScanVolume \Secure (SNANDFLASH) 0.402000
SHIM DLL, LoadRealDll [PalIO.dll] for [AgilentPalIO.dll]
SHIM [AgilentPalIO.dll] Get Process Addresses
LaunchInfiniiVision:
SHIM DLL, LoadRealDll [PalSStorage.dll] for [AgilentPalSStorage.dll]
SHIM [AgilentPalSStorage.dll] Get Process Addresses
Create: \Secure\bin\
Released build, Jun 10 2019, 21:13:39
Initializing FPGA...
Ver: 1.067 Released
*** Liberating License: Acq Memory Max
*** Liberating License: Embedded serial decode and trigger
*** Liberating License: Automotive serial decode and trigger
*** Liberating License: Flex Ray serial decode
*** Liberating License: Power application
*** Liberating License: Segmented Memory
*** Liberating License: Mask limit testing
*** Liberating License: Telecom Mask Test
*** Liberating License: 500MHz Bandwidth
*** Liberating License: 200MHz Bandwidth
*** Liberating License: Audio serial decode and trigger
*** Liberating License: Education kit license
*** Liberating License: WaveGen license
*** Liberating License: 1553 & 429 serial decodes
*** Liberating License: Enhanced Video Triggering
*** Liberating License: Advance Math
*** Liberating License: Flex Ray Plus
*** Liberating License: Digital Voltmeter
*** Liberating License: ASV
*** Liberating License: Cable Calibration
*** Liberating License: Infiniium Mode
*** Liberating License: Remote Log
*** Liberating License: Circular Segmented Memory
*** Liberating License: Tomotherapy
*** Liberating License: F8AEAE82
Calibration mode User
Cal Date Sat Nov 07 00:57:51 2020
Startup sequence is complete.
SHIM DLL, LoadRealDll [PalSysManagement.dll] for [AgilentPalSysManagement.dll]
SHIM [AgilentPalSysManagement.dll] Get Process Addresses
SHIM DLL, LoadRealDll [PalCaps.dll] for [AgilentPalCaps.dll]
SHIM [AgilentPalCaps.dll] Get Process Addresses
SHIM DLL, LoadRealDll [PalWin32.dll] for [AgilentPalWin32.dll]
SHIM [AgilentPalWin32.dll] Get Process Addresses
System has been running 22.839304 seconds
Start Up Sequence 10.222012
Memory Load 58%
System Physical Memory 42.355 / 73.465 MB
Process Virtual Memory 46.875 / 1024.000 MB
-----> InfiniiVision is running <-----
will do USB phy workaround: CheckCRC
Running the hardware Self-Test after a boot:
** self test: PASSED : DDR Mem Bus
** self test: PASSED : Acquisition Memory
** self test: PASSED : ADC
** self test: PASSED : MegaZoom SIPO
** self test: PASSED : TrigComp & Mux
** self test: PASSED : Temp Sensor
** self test: PASSED : FirmwareStatus
** self test: PASSED : Language
I hooked up a LAN chip to the scope so there are associated entries for the network in the log. A stock 1000X would only say "PHY Not found" instead.
I also got the External Trigger mod, all passed.
Not sure if the 2 Megapoints memory is tested in the Acquisition Memory test, but that can be verified by other means.
