Author Topic: EEVblog #978 - Keysight 1000X Hacking  (Read 502059 times)
Offline Mwyann
Re: EEVblog #978 - Keysight 1000X Hacking
« Reply #625 on: September 03, 2019, 05:27:23 pm »
New firmware available, v1.20 (1000XSeries.01.20.2019061038.ksx)
Release notes: https://www.keysight.com/upload/cmc_upload/All/Keysight_1000A_X_Series_Oscilloscope_Release_Notes_01_20.pdf
Looks like they don't made any effort to change over to linux.
If you revert back to the original firmware just use the original v1.10, until I update my code for the v1.20
Hi, any news regarding the 1.20 firmware hack?  ;)
Online alpher
« Reply #626 on: September 04, 2019, 04:50:50 pm »
Hi, could anyone that did the signal gen. in their EDUX1000G's post the correct part numbers needed, especially the package types (ie LM339 ? is it soic or tssop?) , it will be much appreciated.
Thank you.
Offline hv222
« Reply #627 on: September 05, 2019, 02:23:14 pm »
I don't know the exactly part numbers. I used 1% resistors, C0G/NP0 capacitors in signal patch and X7R, X5R (when X7R footprint was too big). Here are teardown photos https://www.flickr.com/photos/eevblog/33024469232/in/album-72157677358745114/
footprints:
U21, U43, U45 - 8 LD SOIC / SO-8
- LM4041CEM3-1.2/NOPB or any other with R1C marking -  SOT32
U22 - SO PowerPAD 8 (be aware, this part is also available on standard SO-8 without thermal pad)
U8, U10, U12 - SOIC-14
Online alpher
« Reply #628 on: September 05, 2019, 06:17:41 pm »
Thank you.
I just added these to my next order.
Offline hv222
« Reply #629 on: September 05, 2019, 08:22:33 pm »
Don't forget about components in power supply patch. There are also unsoldered components - capacitors and linear regulators required for signal generator.
Online alpher
« Reply #630 on: September 05, 2019, 09:14:06 pm »
Damn  :( , capacitors I probably have but regulators probably not, can you share what kind?
Thanks again.
Offline hv222
« Reply #631 on: September 05, 2019, 10:11:46 pm »
Just standard 78xx and 79xx family. All you need you have on teardown photos, except MLCC values. For 0603 footprint I used 100nF, for bigger one something between 1 and 10uF. I don't remember.
Offline tudou2048
  • Country: cn
« Reply #632 on: September 06, 2019, 11:22:49 am »
Maybe 78L05 and 79L05.
Online alpher
« Reply #633 on: September 06, 2019, 01:11:49 pm »
Sounds reasonable, will have to buy some of them.
Thanks guys.
« Reply #634 on: September 08, 2019, 11:58:07 am »
I was going to dump my DS1054Z and buy an MSO5000 but the thing misses the mark on a lot of points so I'm not going in that direction again.
Thus I'm looking at grabbing a DSOX1204G. Does anyone know if there is a crack for the D1200BW2A bandwidth option and the D1200EMBA decode options? I don't need either of them immediately as such so this is an exploratory question.
The following users thanked this post: Free_WiFi, analogRF
Online tv84
  • Country: pt
« Reply #635 on: October 05, 2019, 09:57:16 pm »
Today I had a peek at FERCSA's work.  :clap: Interesting!  ::)
Maybe I can add something to it, although I've never seen a 1000X.
The following users thanked this post: skander36
Offline Fungus
« Reply #636 on: October 10, 2019, 07:47:57 am »
Where can we see it...?
Offline Fungus
« Reply #637 on: October 10, 2019, 07:49:56 am »
Yes, there is.
Online 2N3055
  • Country: hr
« Reply #638 on: October 10, 2019, 08:01:43 am »
Yes, there is.
For 4ch Linux based DSOX1204G ? where?
Offline Fungus
« Reply #639 on: October 10, 2019, 09:10:19 am »
Yes, there is.
Oh, the DSOX1204G   :palm:  :-[ :-[ :-[ :-[
I'm not sure, but look for DSOX2000 and DSOX3000 hacks. I believe the hacks are the same across families.
« Last Edit: October 10, 2019, 09:53:51 am by Fungus »
Offline Cesarsound
  • Country: br
« Reply #640 on: December 15, 2019, 02:26:49 am »
DSOX1102G HKD Decoding I2C data bus from Si4735:
https://youtu.be/lSvhhtFS3_Y
« Last Edit: December 15, 2019, 02:40:10 am by Cesarsound »
Offline TK
« Reply #641 on: December 15, 2019, 03:50:54 am »
Yes, there is.
The DSOX1204G is Linux based, not Windows CE like the 2000X or 3000X.  There is no known hack yet
The following users thanked this post: stafil
Offline skander36
« Reply #642 on: December 15, 2019, 07:26:53 am »
The DSOX1204G is Linux based, ...
[/quote]
Are you sure ? How do you know ? There is some info available ?
Offline skander36
« Reply #643 on: December 15, 2019, 08:28:48 am »
Offline BubbaMc
« Reply #644 on: January 22, 2020, 11:42:17 pm »
Hi all, apologies if this has been covered, but is it possible to hack the EDUX1002A to EDUX1002G or DSOX1002G?
I think it's possible, but just wanted to make sure before I place an order.
Thank you!
Offline Mwyann
« Reply #645 on: February 26, 2020, 04:48:17 pm »
Any news about that work?  ;D
Offline jusaca
« Reply #646 on: February 27, 2020, 07:37:18 am »
At the embedded world yesterday I was told that in a couple of days there will be a new firmware for the Non-EDU versions to increase waveform update rate to 200.000 /s and to always enable serial decode/trigger!
Now I'm waiting quite excited to finally play with the serial options on my 1000x ;)
Offline TK
« Reply #647 on: February 27, 2020, 11:51:22 am »
EDU models can be converted to DSO by changing 2 resistors... does it mean you can have free serial decoding and 200,000wfm/s on EDU models?  Interesting  :popcorn:
Online alpher
« Reply #648 on: February 27, 2020, 06:10:03 pm »
I don't think that it's that simple. Frontend needs substantial rework and sign gen section is  missing  quite a few components. Don't forget about the trigger too.
Offline TK
« Reply #649 on: February 27, 2020, 06:14:55 pm »
I know about the frontend limitation and signal generation section missing (only on A models).  I am just talking about 200,000 wfm/s update rate and serial decoding.
